DIY or mechanic?
DIY or mechanic?
GX460 needs new front and rear brake pads. Is this something I can do, including smoothing the rotors, or should I have the mechanic do it? In that case, the dealership or and independent mechanic? Dealership cost is $750 for front and rear. I am not particularly mechanical, but have the time and can get help and advice from my son-in-law and my friend both of them do their own brake work. Thoughts?
Well, unless you have the proper equipment, you won't be able to "smooth" (turn) your rotors, but most DIYers buy new rotors.
If I were you, I'd pay your relatives to do the job and watch - or find a good indy to do the job.
If you have the time and tools, I would do it myself. I would simply buy new pads and new rotors and just throw those on. Makes for a much faster installation. Turning rotors takes time and sometimes the rotors will be out of spec after turning.
Honestly, disc brakes are pretty dang easy. Couple of jack stands, hands tools and some beers is all you need. As others have suggested don't turn the rotors just replace them.
I'll be honest I don't know if there are any nuances with Lexus for brakes but on everything else I've worked on, which is a lot, it's never been more than a half day job.
I wouldn't do brakes without a lift and power tools - but that's just me.
Super Moderator
GX brakes are pretty easy... that front disc setup with the pins is actually the easiest I've encountered over the years. Wish I had a lift these days.. I'd have to buy a different house. Only had access to one as a youth at my grandfather's place several decades ago. I just use heavy floor jacks and jack stands on my concrete garage floor.
you can put a lift anywhere you can park the GX
a cheap scissor lift <$1000
better ones 1500 or so
some of the portable ones even have the motor and pump on a cart
cheaper ones you crank with a drill
Acrad (08-28-19)
Working on (and learning) things that make the car “Go” is one thing ... because if the car does not “Go” it is difficult to get into too much trouble. Working on the brakes that make the car “Stop” is another matter ... because if the car does not “Stop” things get smashed up and people potentially die.
Working on brakes is “easy” with the proper tools and a basic level of mechanical experience.
and you need a flat area to do the work. You need to be comfortable working in an uncomfortable position and have to be ready to deal with rusted bits that don't want to come apart. Then you have to know what you are doing.
That's not to say that he shouldn't do work on his car, following the crawl/walk/run principle, he should watch a job being done, then do it himself with supervision, then do it all by himself. He may want to start with something that isn't a multi-hour job made worse when working in an uncomfortable position.
Me? I'd start him with a cabin and engine air filter change, move on to a topside oil change, then a "real" oil change and so forth.
We don't want him to say "damn, this is too hard" - we want him to say "what, they charge $200 to change the cabin air filter? It is a 5 minute job with a $20 filter at retail and $10 on Amazon - those five minutes saved me $180. Cool!"
Smokeyyank (08-29-19)
cdnewton
09-29-22 04:46 PM
