2011 Tow wiring question
I have a 2011 GX and the third entry in the maintenance by the previous owner was removing the tow hitch.
I've added the Curt 2" which will suffice for my needs. I have two electrical connections beside the spare.
Is there an adapter to use the factory wiring harness to connect to a 4pole connection for trailer lights?
Thanks for y'all's expertise!
Rob
Rob
Super Moderator
Here are the factory installation instructions.
https://lexusgxor.com/_media/general...ch_install.pdf
I will see if this electrical adapter is sold as a separate part. You may want to check out some of the used parts yards to see if you can obtain off a wrecked 460 as well.
https://www.clublexus.com/forums/gx-...led-parts.html
Super Moderator
Thanks for your quick and thorough help. I appreciate it. Found this which was a direct fit.
Acrad (09-06-19)
