Headlight question
Headlight question
I have a '13 GX base. When turning, I notice only the driver side headlight swivel side to side. The passenger side does not swivel. Could someone verify if both or one side is supposed to swivel? TIA
Hmm I’m not seeing blinking AFS light so that means no fault. I’ll double check swivel function again tomorrow morning when I head out to work. Thanks Acrad
they are both supposed to move. this doesnt mean they both move all the time or the same amount. when you go left, the passenger will go left while the driver wont be able to go left like that. then same thing - but opposite directions/sides - for right turns.
I tried this out in a parking garage and it was apparent that both sides do swivel, independently as John mentioned. Thanks for the feedback guys!
Driver's side moves when you turn left and passenger side moves when you turn right...
John00 (10-09-19)
Super Moderator
This is the range of movement.
My wifes lights move up and down when she starts her truck, but I do not see the AFS button to the left of the steering wheel...is this how the now AFS headlights behave?
Super Moderator
Super Moderator
It should auto-level while driving as well.
the movement is part of the start up check. not sre about the AFS button, some could be now in the small display by the speedometer?
my '12 doesnt have the button.
Super Moderator
I was thinking of my other two vehicles with AFS. Correct... 460 doesn't have a button to deactivate/activate AFS. It is on the dash menu area where 2nd Gear Start, MTS, etc is located
John00 (10-09-19)
@Acrad do you remember if the chart you posted was for 10-13 models or 14+? I swear I've never seen my '14 headlights move while turning, but they do the up/down dance on startup. I feel like I remember reading somewhere that AFS was downgraded to just a vertical adjustment for '14 models?
