LED Upgrade
#46
#47
the loosening is the terminals in the plastic, not the threads coming loose. in some cases the female terminal is too big compared to the male. after hours of vibration, the pins wear in the contact location, eventually losing contact. my experience is about 1-5% have this, so its not a major deal.
if there's an o-ring in that connector then i dont think anything else needs done until theres an issue. if theres not o-ring then i would cover with silicone or black permatex after its all connected
#48
#49
I still fail to understand the issue you are guys are talking about. It is said a picture is better than 1000 words, do you happen to have any picture that illustrate the problem you are referring to? Also is this specifically from this after market LED vendor? Why this is not an issue on OEM halogen bulbs?
i do throw out the failures, these in the pics are marginal, so no pic of the exact issue at the point of failure
you can see corrosion and contamination because some of these did not have o-rings.
that smallest plastic only connector had an o-ring but needed to have the pins bent.
OEM dont use this connector so not a problem for oem. oem also dont have this type of driver.
#52
#53
the grease will help keep out contaminants. this connector has an o-ring and that should be good. the grease also helps reduce wear between terminal pins. wont do much for the housing to terminal wear. but, this might not even be an issue because there's 4. and even if something gets loose you can bend a pin or two.
#54
FWIW I had these on my 4Runner for about 5 years. Those were Xenon Depot HIDs with the same connectors. I never had an issue with them. Granted, sample size of 1. Their output, connectors, overall quality and customer service is what made me a repeat buyer. I have another set sitting on my work bench for my son's '18 4Runner.
#57
These are the running board lights
https://www.vleds.com/shop-bulb-numb...194-26-ho.html
Puddle lights
https://www.vleds.com/shop-bulb-numb...194-14-ll.html
This video made the work easy
https://www.youtube.com/watch?v=0ts5aD5L--I
Puddle lights
#58
The puddles are the lights near the bottom of each door panel.
MarkVII (03-10-20)
#59
They worked perfect on my 2019, so I see no reason they wouldn’t on a 2020. I also picked up another 8 of the 14’s to do the interior domes and map lights. Huge improvement over the dim yellow stock bulbs. Very happy with the Vled bulbs. Total job took maybe 45 minutes working slowly.
csrpenfab (03-11-20)
