Rear window/hatch rusted strut mountings
Old 04-06-15, 12:20 PM
acas1229
acas1229's Avatar
Default Rusting Door Hinge Bolts
Howdy,
Due to the rain this weekend I decided to clean out my interior and do some maintenance. Lately my driver-side door has been making a squeaking sound. As such, I decided to lube up all the doors just in case. Upon inspecting all the doors/hinges I found that both the driver-side rear door and passenger-side rear door hinge bolts are rusted real bad. These are the bolts that connect the hinge to the door rather than the hinge to the door frame. Has anyone noticed this about their door/hinges?
I inspected the door for any sign of water intrusion, but could not see anything out of ordinary. Also, nothing else was rusted or appeared to be water damaged. I inspected all the other hinge bolts around the car for comparison and they were fine. It is strange that both rear passenger doors have this issue. I bought the vehicle used and the Carfax comes back clean with no accidents or damage reported.
The only other time I have seen this is when the door has been worked on, and a socket was used which stripped the protective paint off the bolt. Even then only the rough edges of the bolt rusted, and not the entire thing. While I could foresee one door being worked on, I do find it strange that both would have needed work. However, this assumption does not rule out the possibility.
My only other issue of concern which may play into this is the surprising amount of sand I find on the exterior. As good as one can clean a car there are always some places that will never get fully clean. With that said, while the exterior is clean I have found sand residue in little crevices (weep holes) and corners throughout. I am sure that sand and moisture would play a part in causing rust to accumulate, except that no other parts show any sign of rust. This is certainly bizarre to me. Any suggestions or comments would be greatly appreciated. I plan on replacing the bolts, but would like to remedy the problem before hand if possible.
Thanks - AC
Old 04-06-15, 03:53 PM
rockydog
rockydog's Avatar
All 4 of my door hinges are fine, no rust. Different story on the tailgate. Lifted the rear window and both hinges are significantly rusted.
Old 06-03-17, 06:27 AM
mattau
mattau's Avatar
I recently bought a CPO 2013 GX and asked the dealer and was told that this is "normal wear and tear" and wouldn't fix it as part of the CPO process - even though they fixed the paint chips on the door edges... ???
Anyone else have this problem? How can this be wear and tear? What should I do? What can I do?
Attached Thumbnails Rear window/hatch rusted strut mountings-2017-05-30-08.37.02.jpg   Rear window/hatch rusted strut mountings-2017-05-30-08.36.40.jpg   Rear window/hatch rusted strut mountings-2017-05-30-08.36.54.jpg   Rear window/hatch rusted strut mountings-2017-05-30-08.36.32.jpg
Old 06-03-17, 08:01 AM
User21c
User21c's Avatar
On eBay, you can find little plastic covers for them that fit/look great... they're often listed under Prado parts... from China, about $6 delivered... the also have them for the door latches.
They're supposedly designed to prevent rust, but also look nice...
Old 06-03-17, 08:31 AM
DallasDave
DallasDave's Avatar
I'd like to get some of these covers, but cannot locate ones to fit the GX. I searched using "Prato parts", "prato cover", "door latch cover", etc. Can someone point me in the correct direction?
Old 06-03-17, 08:32 AM
User21c
User21c's Avatar
These things...
http://www.ebay.com/itm/252799870553...%3AMEBIDX%3AIT
and
http://www.ebay.com/itm/221671091457...%3AMEBIDX%3AIT
Old 06-03-17, 08:35 AM
User21c
User21c's Avatar
Itwasa typo... the GX is based on the Prado (with a 'd'), so many parts are interchangeable.
Old 06-03-17, 08:39 AM
DallasDave
DallasDave's Avatar
Ahhh, lol. I can find them now, thx.
Old 06-03-17, 08:48 AM
User21c
User21c's Avatar
For $6, they're really nice.... and snap right on.
Old 06-03-17, 08:50 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
They install really easy too. I put some on mine.
I haven't see any for the rear hatch glass yet...but also haven't looked very hard.
Old 06-03-17, 11:32 AM
bbqsoup
bbqsoup's Avatar
Cheaper here
https://www.ebay.com/itm/121825429185
Old 06-12-17, 08:02 PM
Acrad
Super Moderator
Acrad's Avatar
There is actually a hatch hinge TSB for '10-'12s for corrosion.
Old 06-12-17, 08:21 PM
mattau
mattau's Avatar
no mention of the hatch stays... They finally agreed to replace them. Except the parts are backordered. Thanks for this.
GB2011GX (07-05-17)
Old 07-05-17, 09:36 AM
GB2011GX
GB2011GX's Avatar
Yes, this... just noticed on my 2011. I wonder if I inquire about service history and it never shows them being replaced under warranty if they will still do it? hmmm.
Old 07-06-17, 02:38 PM
Acrad
Super Moderator
Acrad's Avatar
TSBs are a sometimes a hard one to get a dealer to do if out of a bumper to bumper warranty. Mine falls into VIN range but clean as a bell. Probably the southern CA weather kept out the corrosion.
Here are parts on eBay if interested in fixing yourself:
http://www.ebay.com/itm/6881060051-G...-/182546887761
http://www.ebay.com/itm/6882060011-G...-/182382110804
http://www.ebay.com/itm/Lexus-TOYOTA...-/322565323281
GB2011GX (07-07-17)
Quick Reply: Rear window/hatch rusted strut mountings
