FAQ: GX 460 OEM Part Numbers
Old 11-23-19, 10:45 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
Lightbulb FAQ: GX 460 OEM Part Numbers
Updated 7.29.2023
••••🛑 EDIT: Please send me a PM if you come across a part number that has been superseded
Black Line parts are listed in this post.
I am creating this thread so we can consolidate OEM part numbers that are amassed throughout this forum.
Feel free to contribute to thread with ones I will add to this first post or PM.
If you find errors or parts are year specific let me know. IMO: This will save a lot of time for current and future owners. This first post will be edited for quite some time and just getting the ball rolling on info.
Assume 2010-2019 in this first post at this time. As 2020 model year rolls along I will update compatibility.
Parts Schematic Sites
Lexus Parts Search -US
Lexus Parts Search - Canada
Part number suffix and paint color codes:
21 - Atomic Silver/Sonic Titanium (Color Code 01J7) - touch up paint - 00258-001J7-21
A0 - Starfire Pearl (Color Code 077) - touch up paint - 00258-00077-21
B0 - Tungsten Pearl (Color Code 1G1) - touch up paint - 00258-001G1-21
B1 - Knight's Armor Pearl (Color Code 1H3) - touch up paint - 00258-001H3-21
B2 - Nebula Gray Pearl (Color Code 1H9) - touch up paint - 00258-001H9-21
B3 -
B4 -
C0 - Black Onyx (Color Code 202) - touch up paint - 00258-00202-21
D0 - Claret Mica (Color Code 3S0) - touch up paint - 00258-003S0-21
E0 - Satin Cashmere Metallic (Color Code 4U7) - touch up paint - 00258-004U7-21
E1 - Fire Agate Pearl (Color Code 4V3) - touch up paint - 00258-004V3-21
G0 - Peridot Mica (Color Code 6V6) - touch up paint - 00258-006V6-21
J0 - Nightfall Mica (Color Code 8X5) - touch up paint - 00258-008X5-21
'22 Caviar is paint code --> 223
••Still Need to place "Silver Lining Metallic (Color Code 1J4)"
B3 - Platinum Silver ME
Paint Color Codes
[Air Conditioning]
PN: 88320-6A520 / Compressor
PN: 88460-60420 / Condenser
[Air filters]
PN: 17801-38051 / Engine
PN: 87139-50100 / Cabin
[Air Induction Pump Parts / AIP]
PN: 25702-38050 / Valve Set, Emission Control, No .1
PN: 25701-38100 / Valve Set, Emission Control, No .2
PN: 17613-31010 / Cover, Air Pump
PN: 17376-38030 / Gasket, Air Tube, No.1
PN: 17610-0C040 / Assembly, Air Pump
PN: 90166-A0010 / Screw, Hexalobular Tapping
PN: 17617-0C010 / Filter, Air Pump
PN: 17602-0C010 / Cover Sub-Assembly, Air Pump Filter (w/ Air Pump Inlet)
[Alternator]
PN: 27060-38080 (130A) / '10-'19
PN: 27060-38090 (150A) / '10-'13
PN: 27060-38110 (150A) / '14-'19
[Automatic Transmission]
PN: 90341-18059 / Fill Plug
PN: 90301-15004 / Fill plug O-ring
PN: 35178-30010 / AT pan drain plug washer
PN: 35178-30010 / AT pan fluid level check plug washer
PN: 00289ATFWS / ATF Fluid
PN: 9034110011 / AT Pan drain plug
PN: 9034110021 / AT Fluid Level Check Valve
PN: 3533060060 / AT Filter
PN: 9030131014 / AT Filter O-ring
PN: 35106-35170 / AT Pan
PN: 9011906173 / AT Pan bolts
PN: 35168-60010 / AT Pan gasket
PN: 89413-0C011 / Input Speed Sensor
PN: 8941332011 / Output Speed Sensor
PN: 8454035060 / Park Neutral Position Switch Assembly
[Automatic Transmission Cooler]
PN: 32910-60171 / Cooler
[Axle - Front]
[Axle - Rear]
[Backup Light Assemblies]
PN: 81681-60080 / 2010-2013 Left
PN: 81671-60120 / 2013-2013 Right
PN: 81681-60120 /2014-2019 Left
PN: 81671-60160 /2014-2019 Right
[Barn Door Interior Trim]
PN: 67938-60121-A1 / 2010-2019 - Popup window Left Side - Ecru
PN: 67938-60121-B1 / 2010-2019 - Popup window Left Side - Gray
PN: 67938-60121-C0 / 2010-2019 - Popup window Left Side - Black
PN: 67937-60171-A1 / 2010-2019 - Popup window Right Side - Ecru
PN: 67937-60171-B1 / 2010-2019 - Popup window Right Side - Gray
PN: 67937-60171-C0 / 2010-2019 - Popup window Right Side - Black
PN: 67939-60111-A1 / 2010-2019 - Popup window Top Side - Ecru
PN: 67939-60111-B1 / 2010-2019 - Popup window Top Side - Gray
PN: 67939-60111-C0 / 2010-2019 - Popup window Top Side - Black
PN: 67771-58010 / Clips for trim around the rear barn door window
PN: 67761-60060-E0 / 2010-2019 - Compartment door driver side - Sepia
PN: 67761-60060-C0 / 2010-2019 - Compartment door driver side - Black
PN: 75202-60070-E0/ 2010-2019 - Tool kit cover - Sepia
PN: 75202-60070-C0/ 2010-2019 - Tool kit cover - Black
Schematic
[Battery]
PN: 74481-26020 / Clamp hold down
[Belt]
PN: 90916-02680 / 90916-A2023 / - Belt
PN: 166200S012 / serpentine tensioner
[Black Line Edition parts]
PN: PZQ30-60205 / Crossbars
PN: 52030-WY020 + 52040-WY020 / Fog Light Covers
PN: 53101-60M10 + 53112-60340 / Grille
PN: 63460-60110 / 63470-60060 / Roof Rails
PN: 42611-60F80 / Wheels
PN: 75712-60072 / Driver Door Window Belt Moulding
PN: 75711-60072 / Front Passenger Door Window Belt Moulding
PN: 75721-60121 / Right Rear Door Window Belt Moulding
PN: 75722-60121 / Left Rear Door Window Belt Moulding
PN: 81560-WY030 / Tail Light - Left
PN: 81550-WY040 / Tail Light - Right
PN: PZ322-60108 / Rear Bumper Spoiler Sub Assembly
PN: PZ321-60144 / Front Spoiler Sub Assembly
PN: PZ350-60114 / Wheel Hub Assembly Cover
[Blower-HVAC Fan]-front
PN: 87103-60400
[Brake Calipers]
PN: 47730-60300 / Front Right
PN: 47750-60300 / Front Left
PN: 47730-34030 / Right Rear
PN: 47750-34030 / Left Rear
[Brake Pads]
PN: 04465-60320 / Front
PN: 04466-60140 / Rear
[Brake Rotors]
PN: 43512-60191 / Front
PN: 42431-60311 / Rear
[Bumper Cover-Front] (Incomplete Entries)
PN: 521196A952 / 2010-2013 without headlamp washers, without park sensors
PN: 521196A953 / 2010-2013 without headlamp washers, with park sensors
PN: 521196A954 / 2010-2013 with headlamp washers, without park sensors
PN: 521196A955 / 2010-2013 with headlamp washers, with park sensors
PN: 521196B992 / 2014-2019 without fog lamps, without park sensors, without headlamp washers
PN: 521196B994 / 2014-2019 without fog lamps, with park sensor
PN: 521196B995 / 2014-2019 with fog lamps, without pre-crash
PN: 521196B997 / 2014-2019 with fog lamps, with pre-crash
PN: 521190E933 / 2016-2019 without f-sport, without park sensor, without lamp washer
PN: 521190E934 / 2016-2019 without f-sport, with park sensor, without lamp washer
PN: 521190E935 / 2016-2019 without f-sport, without park sensor, with lamp washer
PN: 521190E936 / 2016-2019 without f-sport, with park sensor, with lamp washer
[Bumper Cover - Rear]
PN: 52159-60978 / 2010-2013 without parking sensors
PN: 52159-60979 / 2010-2013 with parking sensors
PN: 52159-6A923 / 2014-2019 without parking sensors
PN: 52159-6A925 / 2014-2019 with parking sensors
[Camera/Rear]
PN: 86790-60120 or 86790-60121 / 2010-2015
PN: 86790-60180 / 2014-2019 without BSM
PN: 86790-60182 / 2015-2019 Rear. Without back monitor. Back up, without blind spot mon.
PN: 86790-60240 or 86790-60241 / 2014-2019 With back monitor. Back up, with blind spot mon
[Cargo Cover]
PN: 64910-60190-C0 / black / 2010-2016
PN: 64910-60230-C0 / black / 2017-2019
PN: 64910-60190-E0 / sepia / 2010-2016
PN: 64910-60230-E0 / sepia / 2017-2019
[Cargo Net]
PN: PT347-60100
[Catalytic Converter]
PN: 17450-38040 or 17450-38110
[Center Console - Upper Panel]
PN: 58821-60381
[Clips - Misc]
PN: 9046710201 / Center Console
PN: 9046712080 / Center Console
PN: 90468-04157 / Center Console
PN: 90467-07217 or 90467-07211 / Radiator Cover
PN: 90467-A0005 / Door Trim Panel
PN: 9046805135 / Center Shifter Console
[Combo Switch on console - DAC/AVS/Crawl/RAHC/4WD]
PN: 84970-60070 / AVS-RAHC-Crawl
PN: 84970-60080 / AVS-RAHC-DAC
PN: 84970-60090 / Crawl
PN: 84970-60100 / DAC
[Console Coin Tray]
PN: 58824-60020
[Control Arm - Front Lower]
PN: 48069-60051(left)
PN: 48068-60051(right)
[Cooling Fan Bracket]
PN: 16380-0S020
[Courtesy Door Lamp Assembly]
PN: 81230-06040
[Crawl Control Switches]
PN: 84970-60090 / 2010-2019 NON-AVS/RAHC models
PN: 84970-60070 / 2010-2019 for AVS/RAHC models (adjustable suspension & Airbags)
[Cross Bars/Roof Rack]
PN: PT278-60170
PN: PT278-60170-FF / Just the front bar
[Cup Holders for second row captain's chairs (17+)]
PN: 55630-12012-A0 ECRU
PN: 55630-12012-C0 BLACK
PN: 55630-12012-E0 SEPIA
[Cup Holder Divider-Front Seat]
PN: 55618-60190 / 2010-2013 models
PN: 55630-60051-E0 / 2010-2013 models (Entire Assembly)
PN: 55630-60030E0 or 55630-60060E0 / 2014-2020 models (Entire assembly)
[Cylinder Head Cover Gaskets]
PN: 11229-38010 / Left and Right
[Differential-Front]
PN: 1215710010 / Front Diff Fill Washer
PN: 9043024003 / Front Diff Drain Washer
PN: 9034124014 / Drain plug (KAON 24mm replacement)
[Differential-Rear]
PN: 1215710010 / Rear Diff Fill Washer
PN: 1215710010 / Rear Diff Drain Washer
PN: 9034118057 / Drain plug
[Dipstick - Engine Oil]
PN: 15301-38080
[Door Edge Guards]
PN: PT9366017008 / Nightfall Mica
PN: PT9366011002 / Black Onyx
PN: PT9366011003 / Claret Mica
PN: PT9366012004 / Fire Agate Pearl
PN: PT9366011011 / Knight's Armor Pearl
PN: PT9366012020 / Nebula Gray Pearl
PN: PT9366011004 / Satin Cashmere Metallic
PN: PT9366012010 / Silver Lining Metallic
PN: PT9366011010 / Starfire Pearl
PN: PT9366011001 / Tungsten Pearl
[Door Handle-Front]-Using Lexus Parts descriptions
PN: 69210-60160-A0 / LEFT & RIGHT. WHITE PEARL CS
PN: 69210-60160-B0 / LEFT & RIGHT. SILVER M.M.
PN: 69210-60160-B1 / LEFT & RIGHT. SPARKLE SOLID GRAY M.M.
PN: 69210-60160-B2 / LEFT & RIGHT. MERCURY GRAY MC
PN: 69210-60160-B3 / LEFT & RIGHT. PLATINUM SILVER ME
PN: 69210-60160-C0 / LEFT & RIGHT. BLACK
PN: 69210-60160-C1 / LEFT & RIGHT. STARLIGHT BLACK GF
PN: 69210-60160-D0 / LEFT & RIGHT. GARNET RED MC
PN: 69210-60160-E0 / LEFT & RIGHT. SLEEK ECRU ME
PN: 69210-60160-E1 / LEFT & RIGHT. FIRE AGATE M.M.
PN: 69210-60160-G0 / LEFT & RIGHT. DEEP PERIDOT MC
PN: 69210-60160-J0 / LEFT & RIGHT. DEEP BLUE MC
[Door Handle-Rear]-Using Lexus Parts descriptions
PN: 69210-60170-A0 / LEFT & RIGHT. WHITE PEARL CS
PN: 69210-60170-B0 / LEFT & RIGHT. SILVER M.M.
PN: 69210-60170-B1 / LEFT & RIGHT. SPARKLE SOLID GRAY M.M.
PN: 69210-60170-B2 / LEFT & RIGHT. MERCURY GRAY MC
PN: 69210-60170-B3 / LEFT & RIGHT. PLATINUM SILVER ME
PN: 69210-60170-B4 / ?
PN: 69210-60170-C0 / LEFT & RIGHT. BLACK
PN: 69210-60170-C1 / LEFT & RIGHT. STARLIGHT BLACK GF
PN: 69210-60170-D0 / LEFT & RIGHT. GARNET RED MC
PN: 69210-60170-E0 / LEFT & RIGHT. SLEEK ECRU ME
PN: 69210-60170-E1 / LEFT & RIGHT. FIRE AGATE M.M.
PN: 69210-60170-G0 / LEFT & RIGHT. DEEP PERIDOT MC
PN: 69210-60170-J0 / LEFT & RIGHT. DEEP BLUE MC
[Door Lock Actuator]
PN: 69040-42250 / Driver's Door
PN: 69030-42230 / Front Passenger Door
PN: 69060-33120 /Rear Driver Side Door
PN: 69050-33120 /Rear Passenger Side Door
PN: 69370-60020 / Rear lift glass latch
PN: 69110-60230 OR 69110-60231 / Rear barn door
[DRL Relay]
PN: 82642-60020 / 2010-2013 US
PN: 82642-47020 / 2010-2013 Canada
[Duct Assembly, Quarter Vent]
PN: 62903-60102 / left and right
[EGR Valve]
PN: 2562038240
[Engine ECU]
2010-2011 / 8966160Q21
2012-2013 / 8966160U40
2014-2016 / 8966160W12
2017-2018 / 8966160U21
2019 / 8966660D20
[Exhaust-Muffler]
PN: 58327-35050 / Heat shields
PN: 1742038160 / Muffler
[Exhaust Tip]
PN: PZ356-60005 / 2010-2020 Black
PN: PT93260120 / Exhaust Tip (Oval)-chrome / Non-Oval chrome ---> PN: PT93260100
[Fender liner]
[2010-2013]
PN: 5380660100 / Front Left
PN: 5380560110 / Front Right
[2014-2023]
PN: 5380660071 / Front Left
PN: 5380560071 /Front Right
PN: 90189-A0002 (Retention clips/grommets) / -
Amazon alternative Amazon alternative
[Floor Mats-All Weather]
PN: PT908-60140-20 / Front & second row - black / 2014-2019
PN: PT908-60143-20 / 3rd row - black / 2014-2019
PN: PT908-60173-02 / Captains chairs - black
PN: PT908-60173-04 / Captains chairs - sepia
PN: PT908-60140-40 / Front & second row / brown / 2014-2019
PN: PT908-60143-40 / 3rd row - brown / 2014-2019
PN: PT908-60100-02 / 2010-2013 - Front & second row - black
PN: PT908-60101-02 / 2010-2013 / 3rd row - black
[Floor Mats-All Weather Floor Liners]
PN: PT908-60170-02 / black (2017-2019)
PN: PT908-60170-04 / sepia (2017-2019)
[Floor Mats-Deep Pile Carpet]
PN: PT208-60114-20 / 2010-2019 (Must remove passenger side hooks ('12-'19)) - Black
PN: PT208-60114-40 / 2010-2019 (Must remove passenger side hooks ('12-'19)) - Brown
[Floor Mats - general carpet]
PN: PT208-76111-25 / Carpeted cargo mat - black / 2014-2017 w/ML
PN: PT208-51152-20 / Carpeted front/second row - black / 2014-2017
[Floor Mat Retention Clips]
PN: 0821000820 / 2010-2013
PN: 58694-76010 (upper) / 2014-2019
PN: 58698-76010 (lower retainer) / 2014-2019
[F Sport]
PN: PTR27-60120 / Wheel-Rim installation kit
PN: PTR5430120 / Grille for 2010-2013 models
PN: PTR56-60120 / Wheel-Rim
PN: PT93260120 / Exhaust Tip (Oval) / Non-Oval ---> PN: PT93260100
PN: PTR2753100 / F SPORT Wheel Lug and Lock Set
[Fuel Injectors]
PN: 23209-39165
[Fuel Pump]
PN: 23220-31430 / Pump only
PN: 77020-35150 / Full pump assembly with fuel gauge sending unit
[Gas / Fuel Cap]
PN: 77300-06040
[Gauge Cluster-Clear Plastic]
PN: 8385260D70 / '10-'19
PN: 838526BV20 / '20
[Glass]
PN: 68105-60230 / Barn Door Flip Up Window
PN: 68124-60380 / GLASS, REAR DOOR QUARTER WINDOW, LEFT
PN: 68123-60380 / GLASS, REAR DOOR QUARTER WINDOW, RIGHT
PN: 56101-60800 or 56101-60300 / Windshield without PCS, Auto High Beams, and Lane Keep Assist
PN: 56101-60810 or 56101-60310 / Windshield with PCS, Auto High Beams, and Lane Keep Assist
PN: 56101-60821 or 56101-60820 / Windshield - Touring Package 2016-2019
PN: 56101-60830 / Windshield - Green,Touring Package 2014-2016
PN: 68102-60610 / Front Driver Side window / 2012-2019
PN: 68102-60620 / Front Driver Side window / 2010-2012 / Green
PN: 68101-60610 / Front Passenger Window / 2012-2019
PN: 68101-60620 / Front Passenger Window / 2010-2012
PN: 68114-60400 / Rear Left Passenger Window
PN: 68113-60400 / Rear Right Passenger Window
PN: 62720-60D80 WINDOW ASSEMBLY, QUARTER, LEFT / 10-13 Premium and 14-20 Luxury
PN: 62720-60E00 WINDOW ASSEMBLY, QUARTER, LEFT / 10-13 base and 14-20 base & premium
PN: 62710-60D10 WINDOW ASSEMBLY, QUARTER, RIGHT / 10-13 Premium and 14-20 Luxury
PN: 62710-60D30 WINDOW ASSEMBLY, QUARTER, RIGHT / 10-13 base and 14-20 base & premium
[Glass Break Sensor Kit]
PN: PT39860111
[Grille]
PN: 53111-60870 / 2010-2013 without radar cruise or front camera
PN: 53111-60880 / 2010-2013 with radar cruise & front camera
PN: 53101-60850 / 2014-2019 without Driver Support Package
PN: 53101-60B30 / 2014-2019 with Driver Support Package
[Headlamp Assemblies]
PN: 81170-60E41 / 2010-2013 halogen LH
PN: 81130-60E81 / 2010-2013 halogen RH
PN: 81185-60E51 / 2010-2013 HID LH
PN: 81145-60E91 / 2010-2013 HID RH
PN: 81185-60G21 / 2014-2019 LED LH
PN: 81145-60G21 / 2014-2019 LED RH
[Headlight Bulbs]
PN: 90981-20024 / 2010-2013 models with HID
[Hood-bug/rock deflector]
PN: PZ451-J8530-ZA
[Idler Pulley]
PN: 16603-38011
[Ignition coils]
PN: 90919A2005 or 9091902256
[KDSS]
PN: 48007-60023 or 48007-60020 / front cylinder
PN: 48886-60032 / rear cylinder
PN: 08886-01805 / fluid
PN: 48006-60031 / Actuator
PN:
48826-60040 / Skid-Protector-Plate
[Key FOB - '10-'19]
PN: 89904-60590 / Full Assembly
PN: 89072-60670 / Housing
[Key blank]
PN: 69515-30300
[LATCH Covers - second row]
PN: 7299660160C0 / Left & Right 10-19 - Black
PN: ​​​7299660160E2 / Left & Right 10-19 - Sepia
[MAF/Mass Air Flow sensor]
PN: 2220475030 or 22204-0F030
[Mirror Glass - sides]
[2014-2020 Left w/BSM/Dimming] - 87961-60P80
[2014-2020 Right w/BSM/Dimming] - 87931-60P80
[2010-2019 Left w/Dimming] - 87961-60B90
[2010-2019 Left w/Dimming] - 87931-60B90
[2010-2020 basic left] - 87961-60E20
[2010-2020 basic right] - 87931-60E20
[Mirror Signal Lamp Assembly]
PN: 81740-60100 / Left
PN: 81730-60130 / Right
[Mudguard - Rear Left]
PN: 7662660290A0 - Starfire Pearl / 2010-2013
PN: 7662660290B0 - Tungsten Pearl / 2010-2013
PN: 7662660290B1 - Knight's Armor Pearl / 2010-2013
PN: 7662660290C0 - Black Onyx / 2010-2013
PN: 7662660290D0 - Claret Mica / 2010-2013
PN: 7662660290E0 - Satin Cashmere Metallic / 2010-2013
PN: 7662660290E1 - Fire Agate Pearl / 2012-2013
PN: 7662660290G0 - Peridot Mica / 2010-2011
PN: 7662660320 - I believe this is unpainted 2014-2020
[Mudguard - Rear Right]
PN: 7662560290A0 - Starfire Pearl / 2010-2013
PN: 7662560290B0 - Tungsten Pearl / 2010-2013
PN: 7662560290B1 - Knight's Armor Pearl / 2010-2013
PN: 7662560290C0 - Black Onyx / 2010-2013
PN: 7662560290D0 - Claret Mica / 2010-2013
PN: 7662560290E0 -
PN: 7662560290E1 - Fire Agate Pearl / 2012-2013
PN: 7662560290G0 - Peridot Mica / 2010-2011
PN: 7662560320 - I believe this is unpainted 2014-2020
[Multi Terrain Select ECU]
PN: 859A1-60020 / 2010-2013
PN: 859A1-60040 / 2014-2019
[Oil Drain Plug, Washer, and Pan]
PN: 90430-12031 / washer
PN:
9034112012 / plug
PN: 1210231010 / pan
[Oil Filters]
PN: 04152-YZZA3
PN: 04152-YZZA5 (if you need End Cap Plug O-ring) - metal cap retrofit mod/if you aren't replacing O-ring just get "A3"
[Oil Filter Metal Cap Retrofit]
PN: 15643-31050 / End Cap Plug
PN: 15620-31060 / Cap Housing
PN:
15620-31040 / Cap Housing without end cap plug
[Oil Filter Plastic Cap] - stock
PN: 1565038050
[Oxygen Sensors (O2)] - These requires additional confirmation
PN: 89467-04060 / Pre-CAT Left & Right /2010-2013
PN: 89467-60140 / Pre-CAT Left & Right / 2014-2019
PN: 89465-36040 / Post CAT-Left/Right Rear / 2010-2013
PN: 89465-0C290 / Post CAT-Left/Right Rear / 2014-2019
[Parking Sensors]
[PCV Valve]
PN: 12204-38010
[Power Steering Pump]
PN: 44310-60570
[Power Steering Reservoir]
PN: 44360-60321
[Power Window Motors]
PN: 85720-47110 / Driver Window
PN: 85710-47110 / Front Passenger
PN: 85720-30431/ Rear Right
PN: 85710-30491 / Rear Left
[Radar Cruise Control Parts List] - Post #40
[Radiator]
PN: 16400-38253 / Assembly
PN: 16401-30020 / Cap
PN: 16572-38151 / Lower Hose
PN: 16571-38100 / Upper Hose
PN: 90466-A0026 / Hose clamps
PN: 1640550051 / Coolant recovery tank cap
PN: 1647031050 / Coolant Recovery tank (cap should be included)
PN: 88590-60091 / Fan assembly
PN: 16711-38170 / Fan shroud
PN: 16371-38010 / Fan pulley
PN: 88453-60010 / Fan blade
[Radiator Fan Clutch]
PN: 16210-38082
[RAHC]
PN: 48910-60042 / Air Compressor
PN: 48090-60020 / Air Bag Left
PN: 48080-60020 / Air Bag Right
PN: 89408-60030 / Height Sensor Left
PN: 89407-60040 / Height Sensor Right
PN: 48950-60030 / Dehydrator
PN: 48925-60050 / Filter
[Rear View Mirror]
PN: 87810-0W460 / ’10-’11 With Auto High Beams
PN: 87810-0W530 / ’10-’11 Without Auto High Beams
PN: 87810-0WB70 / ’12-’19 With Auto High Beams
PN: 87810-0WB50 / ’12-’19 without Auto High Beams
[Recline Handle Caps-Second Row]
PN: 71845-60030-C0 / Right -black
(incomplete list)
[Remote Start Kits]
PN: PT398-60112 / (RES) for 2010-2015 models
PN: PT398-60151 / (RES+) for 2010-2015 models
[Reverse/Backup Light Lense Assembly]
PN: 81681-60080 / Left 10-13
PN: 81671-60120 / Right 10-13
PN: 81681-60120 / Left 14-19
PN: 81671-60160 / Right 14-19
[Running board]
PN: 8215760030 / Harness for lights
PN:
81380-60060 / Light assemblies
[Seat - second row]
Top Lever Sub-Assembly
PN: 7205760130C0 BLACK
PN: 7205760130E2 SEPIA
PN: 7205760130A1 ECRU
[Shark Fin Antenna] - (Best Guess On Colors/May want to double check)
PN: 86760-60100-A0 / 2010-2019 Starfire Pearl
PN: 86760-60100-B0 / 2010-2014 Tungsten Pearl
PN: 86760-60100-B1 / 2010-2014 Knight's Armor Pearl
PN: 86760-60100-B2 / 2015-2019 Nebula Gray Pearl
PN: 86760-60100-B3 / 2015-2019 Silver Lining Metallic
PN: 86760-60100-C0 / 2010-2019 Black Onyx
PN: 86760-60100-C1 / 2012-2016 Description says "STARLIGHT BLACK GF"
PN: 86760-60100-D0 / 2010-2019 Claret Mica
PN: 86760-60100-E0 / 2010-2016 Satin Cashmere Metallic
PN: 86760-60100-E1 / 2012-2019 Fire Agate Pearl
PN: 86760-60100-G0 / 2010-2011 Peridot Mica
[Shift Lock Cover]
PN: 3355460140
[Sill Plates - Front - Illuminated]
Black-Right / 67910-60080-C0
Black Left / 67920-60080-C0
Sepia-Right / 67910-60080-E0
Sepia-Left / 67920-60080-E0
[Skid plates]
PN: 51405-60220 / Front
PN: 51450-60050 / Mid
PN: 51457-60030 / Oil drain cover
PN: 51495-60380 / Transmission cover (plastic)
PN: 77606-60200 / Partial length fuel tank
PN: 77606-60190 / Full length fuel tank
PN: 48826-60040 / KDSS Protector-Plate
[Skid plate bolts]
PN: 90109-06330
PN: 90080-11373 / Old PN: 90119-08A33 (Oil drain cover plate bolts)
(Need other ones)
[Shocks]
PN: 48530-69655 / FRONT 10-19 without AVS left/right
PN: 48510-60260 / FRONT 10-19 with AVS left/right
PN: 48530-69655 / REAR 10-19 without AVS left/right
PN: 48530-69575 / REAR 10-19 with AVS left/right
PN: 89241-60010 / Left & Right AVS actuator
[Smart Card Key]
PN: 89994-48142 (There is a another model that will work but not sure of PN)
[Spare Tire Winch Cover]
PN: 58766-60030
[Spark Plugs]
PN: 909190119
PN: 11193-70010 / tube seals
[Splash Shields - Front Fenders]
PN: 53736-60130 / LH - Front
PN: 53735-35150 / RH - Front
PN: 53886-60030 / LH & RH - Rear
PN: 90467-10186 Retaining Clip
[Spoiler - top of barn door]-Confirm on color with dealer]
PN: 76085-60080-E1 / (Description: FIRE AGATE M.M.)
PN: 76085-60080-G0 / (Description: DEEP PERIDOT MC)
PN: 76085-60082-A0 / (Description: WHITE PEARL CS)
PN: 76085-60082-B0 / (Description: SILVER M.M.)
PN: 76085-60082-B1 / (Description: SPARKLE SOLID GRAY M.M.)
PN: 76085-60082-C0 / (Description: BLACK)
PN: 76085-60082-C1 / (Description: STARLIGHT BLACK GF)
PN: 76085-60082-D0 / (Description: GARNET RED MC)
PN: 76085-60082-E0 / (Description: SLEEK ECRU ME)
PN: 76085-60100-A2 / (Description: WHITE PEARL CS) 2014-2019
PN: 76085-60100-B1 / (Description: SILVER M.M.) 2014-2015
PN: 76085-60100-B4 / (Description: SPARKLE SOLID GRAY M.M.) 2014-2015
PN: 76085-60100-B6 / (Description: MERCURY GRAY MC) 2015-2019
PN: 76085-60100-B7 / (Description: PLATINUM SILVER ME.) 2015-2019
PN: 76085-60100-C0 / (Description: BLACK) 2014-2019
PN: 76085-60100-C1 / (Description: STARLIGHT BLACK GG) 2014-2019
PN: 76085-60100-D0 / (Description: GARNET RED MC) 2014-2019
PN: 76085-60100-E1 / (Description: SLEEK ECRU ME) 2014-2017
[Spoiler Right Cover]
PN: 7689460020 for 10-13
PN: 7689460060 for '14+
[Sport Design Package - Parts List]
[Starter]
PN: 28100-0S060
[Stereo ****]
PN: 86127-60040
[Struts-Doors/Hood]
PN: 53440-0W220 / Hood RH
PN: 53450-0W180 / Hood LH
PN: 68650-09010 / Back Door
PN: 68930-0W020 / Rear Glass RH
PN: 68940-0W020 / Rear Glass LH
PN: 68961-20140 / Glass windows stays for window struts
[Sunroof]
PN: 6326060140 / motor
PN: 6325112190 / seal
PN: 6320160141 / Glass
[Tail Light Assemblies]
PN: 81561-60841 / 2010-2013 Left
PN: 81551-60A01 / 2010-2013 Right
PN: 81561-60B11 / 2014-2021 Left without Sport Package
PN: 81551-60B31 / 2014-2021 Right without Sport Package
PN: 81560-WY030 / 2017-2021 Left with Sport Package - all red
PN: 81550-WY040 / 2017-2021 Right with Sport Package - all red
[Tail Light Socket Wiring]
PN: 81555-60A00 / 2010-2016 both sides
PN: 81555-60B31 / 2017-2019 both sides
[Thermostat]
PN: 16031-38010
[Throttle Body]
PN: 22030-0S021 Throttle Body Assembly
[Tonneau Cover]
PN: 64910-60180-C0 / Black
PN: 64910-60190-E0 / Sepia
[Tool Kit on Back Door-Missing Tools]
PN: 09130-50030 / Pliers
PN: 09141-50050 / 8-10 Spanner Wrench
PN: 09141-50060 / 12-14 Spanner Wrench
PN: 09155-74010 / Spark Plug Wrench
PN: PT420-00080 / First Aid Kit
[Towing Cover]
PN: 52169-60150 / '10-13 - Tungsten Pearl
(Incomplete list)
[Tow Hitch Receiver]
PN: PT22860140 / Assembly
PN: PT72534140 / 7-Pin And 4-Pin Trailer Connector. Towing Wire Harnesses And Adapters
[TPMS ECU]
PN: 8976960050 ('10-'19)
[TPMS Sensors]
PN: 42607-33022
PN: 04423-0E010 / TPMS Seal & Repair Kit (No longer included)
[TPMS Receiver]
PN: 8976060050 (10-13)
[Trailer Brake Wiring Harness]
PN: 82132-60110
[Transfer Case]
PN: 36100-6D401 / Assembly
PN: 08885-81080 / Fluid
PN: 90430A0003 / Fill washer
PN: 90430A0003 / Drain washer
PN:
9034118006 / Drain plug
PN: 0436260881 / Overhaul Gasket Kit
[USB Jack - Front]
PN: 86190-53040 / 2010-2013
PN: 86190-53051 / 2010-2019
[Valve Cover Gaskets]
PN: 11213-0S010 / Right
PN: 11214-0S010 / Left
[Water Pump]
PN: 16100-09525 / pump
PN: 1627138030 / gasket
[Weatherstripping Rear Door Frame]
PN: 67871-60130 / Right
[Weatherstripping Rear Door Opening]
PN: 62332-60101-C0 / Left
[Wheels]
PN: 0027600901 - locks
PN: Thread on topic - Rims
[Window Belt Moldings] - Window external
PN: 75712-60090 / Driver door
PN: 75711-60090 / Front Passenger door
PN: 75721-60090 / Right Rear Door
PN: 75722-60090 / Left Rear Door
[Windshield lower corner moldings]
PN: 53867-60090 / Driver Side
PN: 53866-60090 / Passenger Side
[Windshield Molding Clips]
PN: 75545-53011
[Windshield - Rain Sensor - Gel Pack]
PN: 89944-42010
[Windshield Reveal Molding]
PN: 75535-60020 / Passenger Side
PN: 75536 -60010 / Driver Side
[Windshield Washer Pump]
PN: 85330-60190
[Windshield Wiper Full Blade Replacements/Frame]
PN: 85212-YZZ2H-LX / Driver (Reportedly this frame cannot take an insert)
PN: 85212-YZZ2E-LX / Passenger (Reportedly this frame cannot take an insert)
PN: 85252-YZZRE-LX / Rear
PN: 852220E040 / Driver (Reportedly this frame can take an insert)
PN: 8521253081 / Passenger (Reportedly this frame can take an insert)
[Windshield Wiper Inserts]
PN: 85214-60120 / Passenger Side
PN: 85214-02340 / Driver Side
PN: 85214-42040 / Rear
Acrad is offline
The following 15 users liked this post by Acrad:
bbqsoup (09-01-22), blackangus (11-23-22), Craigyyy (11-23-19), hzhao (11-03-20), mail2anoopmv (11-18-23), MIA IS250 (03-02-22), nuclearn8 (11-25-19), ObsidianBl (11-23-19), paui4m (11-23-19), Romanova (09-23-20), rw3 (05-11-23), Satcoman (05-20-23), SteveInCal (11-26-19), tecman (11-30-19), thiggins (11-19-20) and 10 others liked this post. (Show less...)
Old 11-23-19, 11:26 AM
Craigyyy
Craigyyy's Avatar
Engine Air Filter Toyota 17801-38051
Cabin Filter Toyota 87139-50100
+1 I use 04152-YZZA3 oil filter for my stock 2011 GX. There were a few to choose from, slightly confusing.
Craigyyy is offline
The following 2 users liked this post by Craigyyy:
Acrad (11-23-19), rw3 (05-11-23)
Old 11-23-19, 02:52 PM
Acrad
Super Moderator
Acrad's Avatar
2022 Specific Parts
PZQ3060205 - Blackline Cross Bars
Caviar paint code --> 223
Acrad is offline
The following 2 users liked this post by Acrad:
Nickk6 (04-06-22), rw3 (05-11-23)
Old 11-24-19, 09:34 AM
Acrad
Super Moderator
Acrad's Avatar
2020 Specific Parts
[Bumper Covers]
PN: 52119-6B992
PN: 52119-6B998
PN: 52119-6B999
PN: 52119-6C901
[Center Console]
PN: 58903-60880-C0 / Black
PN: 58903-60880-A0 / Ecru
PN: 58903-60880-E0 / Sepia
[Center Console USB ports (rear)]
PN: 85532-50020 (doesn’t include wiring harness)
[Crawl Switch]
PN: 84970-60450 - AVS/RAHC/DAC/Crawl/MTS
[Emblem-Rear]
PN:
90975-02164
[Grille]
PN: 53101-60G30
PN: 53101-60G40
For completing grill here is a bit I obtained from Bell Lexus North Scottsdale: "There are two pieces really that would go under that. The first is the cover ( 52719-60040 ). That is in the attached diagram as 52719. The other is the lower grill (53112E). There are two part numbers for that, both are included here below and a snapshot of the fitments is attached as well
53112-60330
53112-60340
[Grill emblem]
PN: 53141-50060
[Headlights]
PN: 81145-60Q00 / Passenger side
PN: 81185-60P70 / Driver side
[Key FOB]
PN: 8990460U80
[Shift boot assembly]
PN: 58808-60510-C1 / Black/Lt Brown trim
PN: 58808-60510-C2 / Black/Crimson trim
[Shift ****]
PN: 33504-48110-C0
[Skid Plate - Full Length Gas Tank]
PN:
77606-60190
[Wheels/Rims]
PN: 42611-60E80 / 19" Luxury rim
Acrad is offline
The following 3 users liked this post by Acrad:
KOOLFELLA (02-03-20), rw3 (05-11-23), SamLexRXGX (09-16-20)
Old 11-30-19, 02:11 PM
Acrad
Super Moderator
Acrad's Avatar
I need to confirm further on front bumpers and start up with rear bumpers.
The side mirrors & components in all the different colors are next.
Can you think of any other common parts that break or "get" broken by a garage or other object?
Acrad is offline
Old 11-30-19, 03:12 PM
tecman
tecman's Avatar
Shark fin antenna and rear spoiler have been brought up a few times here with garage door or shark fin in a low parking deck.
Thanks Acrad
tecman is offline
Acrad (11-30-19)
Old 12-12-19, 03:51 PM
Acrad
Super Moderator
Acrad's Avatar
2020 parts are now online.
https://parts.lexus.com/Lexus_2020_GX-460-46L-AT.html
Acrad is offline
Old 01-11-20, 07:51 AM
Acrad
Super Moderator
Acrad's Avatar
GUIDES --- ***I may park this info in another documentation thread at some point but will place here for now. This post will also be edited for some time. Let me know if you see any broken or incorrect links. There are a lot of links here.
[Accessories]
2011 GX 460 Accessories - Russia
2013 Accessory Application Chart
2015 GX 460 Accessories - Russia
2017 Lexus SUV Accessories
2017 Lexus Accessories Reference Guide
2018 Lexus SUV Accessories
2019 Lexus SUV Accessories
2020 GX 460 Accessories - Russia
Crossbar Installation
Exhaust Tip Installation
Glass Break Sensor Owner's Guide (2010-2019)
Remote Engine Starter Owner's Guide (2010-2015)
Remote Engine Starter Plus Owner's Guide (2010-2015)
Russian 2010-2013 Catalog
[Brochures-Canada]
2014
2015
2016
2017
2018
2019
[Brochures-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2020 (Puerto Rico)
[Brochure-World-outside of US/Canada]
2012 GX 460 Service/Maintenance Schedule Russia
2014 GX 460 Russia
2017 GX 400 China
2018 GX 460 Oman
2019 GX 460 Bolivia
2019 GX 460 Costa Rica
2019 GX 460 Kazakhstan
2019 GX 460 Philippines
2019 GX 460 Russia
2019 GX 460 UAE
2019 GX 460 Vietnam
2020 GX 460 Kazakhstan
2020 GX 460 Russia
2020 GX 460 Vietnam
[Multimedia Owner's Guides-USA]
2014
2015
2016
2017
2018
2019
2020
[Navigation/Owner's Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Navigation/Owner's Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Owner's Manuals-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Owner's Manuals-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Owner's Manuals/Navigation Guides-outside of North America]
2020 - Russia Owner's Manual
2020 - Russia Navigation Guide
2020-UAE Owner's Manual
[Personalized Settings ]
2010-2013
2014-2019
[Product Info-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Quick Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Quick Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Specification Sheets-Canda]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Specification Sheets-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Warranty/Service Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Warranty/Service Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
[Trim Sales Breakdown from US Specification Sheets]
2010
2011
2012
2013
Conversion parts
Acrad is offline
blackangus (11-23-22), eketony (08-04-20)
Old 06-27-20, 12:23 PM
Acrad
Super Moderator
Acrad's Avatar
[Schematics]
Engine/fuel/tool
0901: STANDARD TOOL
1101: PARTIAL ENGINE ASSEMBLY
1102: SHORT BLOCK ASSEMBLY
1103: ENGINE OVERHAUL GASKET KIT
1104: CYLINDER HEAD
1105: CYLINDER BLOCK
1106: TIMING GEAR COVER & REAR END PLATE
1107: MOUNTING
1201: VENTILATION HOSE
1301: CRANKSHAFT & PISTON
1302: CAMSHAFT & VALVE
1501: ENGINE OIL PUMP
1502: OIL FILTER
1601: WATER PUMP
1603: RADIATOR & WATER OUTLET
1605: V-BELT
1701: MANIFOLD
1702: EXHAUST PIPE
1703: AIR CLEANER
1706: MANIFOLD AIR INJECTION SYSTEM
1708: VACUUM PIPING
1901: IGNITION COIL & SPARK PLUG
1903: ALTERNATOR
Acrad is offline
Old 11-01-20, 07:33 AM
Acrad
Super Moderator
Acrad's Avatar
[Schematics]
Engine/fuel/tool (cont)
1904: STARTER
1904: STARTER
2211: FUEL INJECTION SYSTEM
Acrad is offline
Old 11-01-20, 07:46 AM
Acrad
Super Moderator
Acrad's Avatar
[Schematics] ••Note: I will need to add in schematics that differ for '14+ models.
Power Train/chassis
3312: SHIFT LEVER & RETAINER
3501: TRANSAXLE OR TRANSMISSION ASSY & GASKET KIT (ATM)
3502: TORQUE CONVERTER, FRONT OIL PUMP & CHAIN (ATM)
3503: TRANSMISSION CASE & OIL PAN (ATM)
3507: BRAKE BAND & MULTIPLE DISC CLUTCH (ATM)
3508: CENTER SUPPORT & PLANETARY SUN GEAR (ATM)
3509: BRAKE NO.3, 1ST & REVERSE BRAKE (ATM)
3510: PLANETARY GEAR, REVERSE PISTON & COUNTER GEAR(ATM)
3512: VALVE BODY & OIL STRAINER (ATM)
3513: THROTTLE LINK & VALVE LEVER (ATM)
3514: OIL COOLER & TUBE (ATM)
3608: TRANSFER ASSEMBLY & GASKET KIT
3609: TRANSFER CASE & EXTENSION HOUSING
3610: TRANSFER GEAR
3611: TRANSFER LEVER & SHIFT ROD
3617: TRANSFER OIL PUMP
3701: PROPELLER SHAFT & UNIVERSAL JOINT
4101: REAR AXLE HOUSING & DIFFERENTIAL
4102: REAR AXLE SHAFT & HUB
Acrad is offline
Old 11-01-20, 07:57 AM
Acrad
Super Moderator
Acrad's Avatar
[Schematics]
Power Train/chassis (cont)
4103: DISC WHEEL & WHEEL CAP
4301: FRONT AXLE HOUSING & DIFFERENTIAL
4302: FRONT DRIVE SHAFT
4303: FRONT AXLE HUB
4501: STEERING COLUMN & SHAFT
4502: VANE PUMP & RESERVOIR (POWER STEERING)
4503: POWER STEERING TUBE
4504: STEERING WHEEL
4505: FRONT STEERING GEAR & LINK
4601: PARKING BRAKE & CABLE
4701: BRAKE PEDAL & BRACKET
4702: BRAKE MASTER CYLINDER
4705: FRONT DISC BRAKE CALIPER & DUST COVER
4707: REAR DISC BRAKE CALIPER & DUST COVER
4708: BRAKE TUBE & CLAMP
4802: FRONT AXLE ARM & STEERING KNUCKLE
4803: FRONT SPRING & SHOCK ABSORBER
Acrad is offline
Old 11-01-20, 07:59 AM
Acrad
Super Moderator
Acrad's Avatar
[Schematics]
4804: REAR SPRING & SHOCK ABSORBER
4805: HEIGHT CONTROL (AUTO-LEVELER)
Acrad is offline
Old 11-01-20, 12:24 PM
Acrad
Super Moderator
Acrad's Avatar
Body/interior Diagrams (Cont)
5855: CONSOLE BOX & BRACKET
6151: SIDE MEMBER
6151: SIDE MEMBER
6152: SIDE WINDOW
6153: ROOF PANEL & BACK PANEL
6155: REAR VENTILATOR & ROOF VENTILATOR
6451: INSIDE TRIM BOARD
6452: ROOF HEADLINING & SILENCER PAD
6751: FRONT DOOR PANEL & GLASS
6753: FRONT DOOR LOCK & HANDLE
6754: FRONT DOOR WINDOW REGULATOR & HINGE
6755: REAR DOOR PANEL & GLASS
6756: REAR DOOR LOCK & HANDLE
6757: REAR DOOR WINDOW REGULATOR & HINGE
6761: BACK DOOR PANEL & GLASS
6762: BACK DOOR LOCK & HINGE
6765: LOCK CYLINDER SET
7151: SEAT & SEAT TRACK
Acrad is offline
Quick Reply: FAQ: GX 460 OEM Part Numbers
