Alternator
Wiring and mounting sure does look the same to me... score for when mine fails!
Even cheaper too!
https://www.oemgenuineparts.com/oem-...tor-2706038050
Stock Alternator Amperage
I have a 2011 GX460 Base. Does anyone know what the stock alternator amperage rating is? I see two choices when buying on rockauto.com, a 130 amp and a 150 amp. The 150 for some reason is cheaper than the 130, but I'm not sure which one I need to get. Both options I'm looking at are Denso.
Super Moderator
A couple threads.. consensus has been 150 was stock for 3-zone HVAC.... I'd go with the 150 if going near stock
https://www.clublexus.com/forums/gx-...a-or-150a.html
https://www.clublexus.com/forums/gx-...lternator.html
Thank you very much! Guess I get the 150A. Fine with me as it's cheaper anyways!
ronsatour5 (08-26-22)
Biggerer is Betterer ... assuming plug-and-play (same electrical connectors and physical fitment).
I guess we'll find out if it's all plug and play. I see the "3 Zone" option when I'm selecting climate options in the car. So I'm assuming that's what they're referring to in the other thread. We'll see.
The Biggerer the Betterer !
Super Moderator
Super Moderator
