After Market Fog Location
I purchased a 15' GX without any fog lights and I miss them. I purchased it pre-owned and the only other GX's with fogs weren't as nice so I opted to get one without fogs.
I really want to get these Baja Designs Squadron-R SAE, Pair LED Wide Cornering, Amber https://amzn.to/2G3PIub (these ones are DOT approved) but the size dimensions are 3.07" x 2.77" x 3.07" so they will not fit in the factory fog locations. have others had this issue? where are you putting your after market fog lights if they are not in the factory location.
I looked at the lower grill area but worry about light beams being blocked with the honeycomb. it does look like there is some metal areas I can easily mount the brackets to either hanging the bracket or putting bracket face down. it would require me removing either the bumper or the grill to get to.
Super Moderator
Not sure if this helps but an older thread about adding fogs.
https://www.clublexus.com/forums/gx-...od-for-gx.html
Photobucket charging $$ really ruined many threads. Not sure where they are now but I thought it was a few hundred dollars a year to keep your photo library. Glad I never used it.
Super Moderator
Yeah...I never used it either. I try to upload here barring any upload limitation (25 pictures per post) or Google Photos.
and I agree. photobucket is lame sauce. I use flickr to host but even now they are charging way too much
nobody has after market fog lights in another location!?
