FAQ/SEARCH-Maintenance/MODS/Repairs/Diagnostics/Info/Service Campaigns/Recalls/OBD
Super Moderator
Updated 1.27.2024
[Maintenance/Repairs]
ABS Sensor Wires
AC/Air conditioner compressor replacement
AC evaporator cleaning-air conditioning
Aftermarket Parts for '10-'13 Premium / 14+ Luxury with AVS and RAHC
Air Filter replacement - Cabin
Air filter replacement - Engine
Alarm intermittently going off
Alignment
All Weather Floor Mats
Alternator
Arm Rest Disassembly
Automatic Transmission Failure or Issues
Automatic Transmission Fluid
AVS actuator removal
Axle Seal
Ball Joints
Barn/Rear Door Adjustments
Barn door - Emergency Release or stuck open/closed
Barn door gate latch mechanism lubrication
Barn door - lift up glass removal
Battery - questions, concerns, and/or problems
Belt molding - windows
Blind Sport Monitoring - BSM
Bluetooth Voice Quality Adjustments
Block Heater
Blower motor replacement (front)
Brake Emergency/Parking Brake Adjustment / Thread #2
Brake fluid flushing/bleeding/power bleed/Techstream
Brakes Issues/Problems
Brake Pads - Front
Brake Pads - Rear
Bumper/Fender Gap
Bumper/Grille removal - (2014-2019)
Bushing - Sway Bar - Rear
Camshaft Sub Assembly Gasket
Cargo Area Hooks and Nets
Chassis Lubrication: zerks/driveshaft/prop, spiders, and slide yokes
Coolant Flush / Fluids / Questions / Comments / (PDF)
Coolant Valley Plate Leak
Console Cooler / Cool Box
Console Replacement-Upper Panel
Cup holders
Cup Holder - Wood trim removal
CV boot / axle replacement
Differentials Fluids
Differentail Front Pinion Seal Leak
DIY maintenance quick reference
Door handle (exterior) - problems, questions, concerns
Door handle - cracked alternate replacement
Door Lock Actuator
Door Lock Q&A
Door Panel Removal - Front Doors
Door - Rear Barn Door Adjustment
Door - Rear Barn Door Panel Removal / (PDF)
Drive Shaft Inboard Joint Boot Leak (TSB)
EGR Valve Removal
Electrical Connectors LINK #1 / Link #2
Fan clutch
Fender liner removal and installation
Fog light bulb replacement 2010-2013
Fuel filter replacement
Fuel Pump
Fuel System Cleaners
Fuses
Gauge cluster disassembly
Glove box will not stay closed
Head gasket
Headlight aiming
Headlight aiming (10-13 HIDs)
Headliner Removal
High Mileage Maintenance
Hub replacement
HVAC - Air Conditioning / Heating - Troubleshooting / (Front Disassembly-PDF)
HVAC -Odors
HVAC - recirculation behavior
Instrument Cluster Removal & Disassembly
Jack Points
KDSS Diagnostics / Problems
Key fob battery replacement
Key Fob Problems & Questions
Lean (KDSS)
Leather questions, concerns, problems, mods and fixes
License plate panel - rear
Maintenance Required - Reset
MAF & throttle body cleaning
Mirror (sides) problem/repairs/questions / (Outer Mirror Disassembly/PDF)
Multi Terrain Select (MTS) 2020+ malfunction
Noise under rear of vehicle after 5 hours
Oil & Filter change
Oil Level or Pressure sensors
Oxygen (O2) Sensors
Park/Neutral position switch
Parking Sensors (Intuitive Park Assist)
Parts schematic sites
PCV valve
Power steering fluid replacement
Power Window Issues
Radiator replacement
Radio/Stereo/Navigation Issues Problems '2010-'2013
Radio/Stereo/Navigation Issues Problems '2014-'2021
Radio/Stereo/Navigation Issues Problems 2022-2023
Radio/Stereo/Navigation Removal
Rain Sensor
Rattle / noise - rear wheel well
Rear window/hatch rusted strut mountings
Reverse/Backup light replacement
Rotors
Rust-Underbody / Doors / Rust Guide @ GXOR
SAIP bypass - Hewitt-Tech
Scratches - Interior
Seat - 2nd Row Fold Repair
Seat Belts
Seat Comfort / Uncomfortable/Seat Jackers
Seat (Front Row) Rear Panel Removal
Seat - front cooling/heating switch replacement
Seat Heater - Front
Seat Ventilation / Cooler Questions & Comments
Second row seat squeak ('10-'15 models)
Secondary Air Injection Pump (SAIP)
Shark Fin Repair
Shifter - Squeaky
Shocks/Struts/Coilover / alternate thread / (Front-PDF)
Skid plate brace replacement
Smog sensor cleaning
SOS Light Issues/Problems
Spark plug replacement
Spark Plug Well Filled with Oil
Spoiler - oxidized
Starter Replacement
Steering wheel creak/rattle/other noises
Steering Rack / flutter
Steering Wheel Removal
Sunroof/Moonroof maintenance - clean drains
Sunroof Seal
Thermostat
Third Brake Light Replacement
Throttle body replacement
Timing Chain Cover Oil Leak / TSB on leak or seep & warranty
Timing Issues
Tires replace 2 tires or 4 tires, when you get a flat…
Tire Rotation
Touch up paint codes
TPMS Diagnostic via OBD port wire (Post 256)
TPMS Sensors program with TS / Selection of replacement TPMS sensors
Transfer Case Fluids /Center Diff/Torsen
Transfer case leak/Center Diff /Torsen
Undercoating
Used Oil Analysis (UOA)
Used/Recycled Parts
V-belt replacement
Vibration issues
Water Leaks - Interior
Water Pump / Repair / Leak / (PDF)
Wheel alignment specifications
Wheel Bearing Replacement / C1403
Whine / Whining noises
Wind Noise
Windshield
Wiper Arm Replacement Rear Window
Wiper blade refills
Wiper blade replacement- Rear
[Modifications]
2010-2013 conversions to 2014+
'2020+ grilles on '14-'19
AFEPower Intake for GX 460
A760F Transmission mods / Transmission Overview #1 / Transmission Overview #2 (460 specific)
Air Horn
Air pump uni filter mod
Accessory power to second row (USB)
Adaptive Radar Cruise Control and Pre Collision (PCS)-add
Amazon Alexa
Android Auto
Apple CarPlay
Automatic Transmission Cooler Install - OEM / Aftermarket Install / Hose Routing
Backup Camera with grid lines
Backup camera washer
Baja Designs Squadron-R SAE Wide Cornering in Amber
Beatsonic - Surround Camera View Install / Project Completion
Breathers
Bug / rock hood deflector
Bumpers-overlanding
Brake controller install for trailer
Canvasback
Captain’s Chairs
Car Cover
Cargo area release button
Cargo area organizers
Cargo area pet/dog barrier or crates
Cargo area power options
Cargo carriers
Cargo Mats
Catalytic Converter Protection
Chrome Delete
Console Vault
Crawl Control and Multi Terrain Select / Detailed MTS Install
Crawl Control - Budget install
Crossbars
Cup holders
Dashcam/Radar Detector Installations
Dashcam/Radar Detector power off mirror (2020+)
Debadging
Digital Speedometer
Diode Dynamics Fog Light Upgrade
Disable dash lights after removing air suspension/AHC
Door Edge Guards
Door Moldings
Door Sills/Scuff plates - illuminated
Drawers
Drink Holder Insert
Efficiency (fuel)
EGR delete
Exhaust / muffler - aftermarket
Fender Flares
Fender Liner mod for larger tires / Tire rub bolt with larger tires / Wheels
Fender liner replacements (Front)
F-Sport grille for '10-'13 and removal
Fog Light - Rear
Forced Induction
Front Differential Drain Plug Replacement 24mm
Glass Breakage Sensor add-on to factory alarm
Glove box storage options
Grill 2014-2019 removal
GromAudio VLine VL2 Infotainment System Upgrade / Installation in '10-'13
Hail Protection
Headlight blackout (10-13)
Headlight conversion - aftermarket 2020 style for '14-'19
Headlight conversion - OEM 2020 for '14-'19
Headlight high beam conversions '10-'19
Headlight washers
Heated Seats - Add for '14-'19 models not equipped
Heated steering wheel
High Beams Automatic
Hitch Install-OEM
Hidden Tricks
Hidden Winch Mount
Horsepower/power mods
HUD
Invisacord install
KYB AVS shock exact replacement alternative
Lane Change Auto Flasher / blinker - Tail Light
LED conversions
LED door handle and footwell
LED fogs to base model 14-19
Leveling kits
License plate questions, comments, concerns
Lighting - interior & running board
Lifted
Lockers
Magnaflow
Mirrors - Auto Folding
Mirrors - Manual to power folding retrofit
Mirrors - Towing
Morimoto fog light upgrades on '10-'13
Navigation and DVD bypass "cheap" (10-19)
Navigation - stock retrofit
OEM Crossbar Roof Rack Utility Clamps
Oil filter cap replaced with metal version
Paint Protection - 3M, Xpel, etc
Pedal Commander
Phone/Tablet mounts
Radar detector
Rear Door Ladders
Rear Door - Prado 150 series replacement
Rear Door Tables
Rear seat entertainment installation
Rear Seat Entertainment Options - Aftermarket
Rear window - prop open (Post #71)
Recovery Gear
Remote Start - Enform
Remote Start (RES) Install/Questions for '10-'15 models (Reports of "not-compatible" on Canadian vehicles)
Roof rack/bars
Roof Rail Delete
Roof Rails Upgrade
RSES (Rear Seat Entertainment System)
Running Board Removal
Seat Covers
Seat Reconditioning
Side Windows Shades
Subwoofers
Tint
Tuning - Engine
Turn Signals - LED
Turn Signals (Sequential) - Retrofit - Front
Turn Signals/Tail Lights (Sequential) - Retrofit - Rear
Scangauge
Second row seat delete
Skid Plates/Sliders
Smart Card Key and FOB Programming
Smart Key functionality on rear door handles
Soft close latches
Spacers
Speakers
Sport Design Parts for conversion
Surround view cameras install
Taillight - All Red / Differences between 10-16 & 17+
Tablet/ Tesla style screen / Resistor fix for airbag light
Third row seat questions, concerns, other info
Third row seat removal / 3rd row delete
Timbren
Toolkit - Missing Pieces
TPMS Delete
Trim removal & sound deadening
Vinyl Wraps
Washer pumps
Washer tank relocate
Weathertech floor liners and all weather mats
Weathertech Window Deflectors
Windshield Shades
ZPC - Zero Point Calibration (PDF)
[Customizations/Diagnostics]
Automatic transmission temps via OBD & OBD Fusion/Link phone app /Monitor status of torque converter lockup
TPMS Readings via OBD port
HVAC Diagnostics without Techstream
OBD Fusion/Link - Read extended OBD Codes that often requires Techstream (via OBD2 port) - OBD Link
Startup Screen - '14+
Vehicle Personal Setting Customizations
HVAC temp shift setting
Techstream
[Firmware]
'10-'13 Diagnostic mode on Infotainment
'10-'13 navigation system and firmware update bug fixes
'14-'20 Diagnostic mode on Infotainment
'14-'23 navigation/infotainment firmware
[Info]
1UR-FE technical info
3rd Gen Discussion
AFS discontinued on 460 after 2013 model year
Airbags & Frame - Safety
Alternator - various sizes
Am I Grade G or Z (Parts Inquiries)?
Amplifier location
Approach / Departure / Breakover
Areas to check before purchase or powertrain warranty expiration
ATF Thermal Degradation Estimate
AVS - Adaptive Variable Suspension discussion
Boat, Travel or Other Trailer Towing Experience
Body Dimensions
Cargo Space Volume/Dimension
Commercials
Cross Shopping
Driver Support Package
ECO Mode/Light
Error Messages Related to AFS/AVS/RAHC after putting on lifts
ETCS-i overview
Extended Warranty
Fuel - Type - Premium or Regular / Octane
Highest Mileage
Hill-Start Assist Control
Instrument Cluster Language & Display Unit Changes
Just for fun video thread
KDSS Overview
Lexus navigation generation & version grid
Lexus vehicle build info via VIN
Mark Levinson (ML) discussion / questions / problems
Monthly/Yearly GX sales figures (Canada/US Sales)
MPG Discussion
Reviews
RAHC (Rear Adjustable Height Control) components
RCSA button
Roadside Assistance
Snow or Ice Driving Questions/Concerns/Experiences
Stock Rim Options - model years
Timing chain or belt?
Torsen Diff (VF4BM) - Technical overview - transfer case
Torque Specifications
Trim & Unit Production Numbers
Two Row (5-seater) 460s in markets outside of North America / No third row stock - five
Vehicle Data Recorder
VIN Locations
Voice commands
Winter tires or snow chains
[Recalls/Service Campaigns] - Open
2010-2013 Special Service Campaign (JLG) for Air Injection Pumps and Air Switching Valves
2010-2017 Takata airbag recall info ('10- to early '17 models)
2010-2018 Data Communications Module Campaign
2014-2015 & 2018-2019 Fuel Pump Recall (Safety Recall 20LA01)
2010-2018 - Lexus Enform EOL 3G (10.31.2022)
[OBD Codes]
B1423 - Pressure Sensor Circuit
C1201 - Engine Control System Malfunction
C1210 - Zero Point Calibration of Yaw Rate Sensor Undone
C1336 - Zero Point Calibration of Acceleration Sensor Undone
C1407 - Open or Short in Rear Speed Sensor RH Circuit
C1408 - Open or Short in Rear Speed Sensor LH Circuit
C1452 - Accumulator Low Pressure
C1831 - Accumulator Solenoid Malfunction / Upside
C1832 - Accumulator Solenoid Malfunction / Downside
C1851 - Low Pressure Malfunction in Upside of KDSS System
C1853 - High Pressure Malfunction in Upside of KDSS System
P006A - EGR Valve
P0037 / P0038 / P0057 / P0058 / P102D / P105D
P0355 / P0337 / P0338 / P0339
P0705 - Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0761 - Shift Solenoid "C" Performance (Shift Solenoid Valve S3)
P1603 - Engine Stall History
P1604 - Startability Malfunction
P1605 - Rough Idling
P2111 - Throttle Actuator Control System - Stuck Open
P2112 - Throttle Actuator Control System - Stuck Closed
P2121 - Throttle / Pedal Position Sensor / Switch "D" Circuit Range / Performance
P2440 - Secondary Air Injection System Switching Valve Stuck Open Bank 1
P2441 - Secondary Air Injection System Switching Valve Stuck Closed Bank 1
P2442 - Secondary Air Injection System Switching Valve Stuck Open Bank 2
P2443 - Secondary Air Injection System Switching Valve Stuck Closed Bank 2
P2444 - Secondary air injection (AIR) pump, bank 1 – pump stuck on
P2445 - Secondary air injection (AIR) pump, bank 1 – pump stuck off
P2447 - Secondary air injection (AIR) pump, bank 2 – pump stuck on
P2448 - Secondary air injection (AIR) pump, bank 2 – pump stuck off
P2714 - Pressure Control Solenoid "D" Performance (Shift Solenoid Valve SLT)
Transmission Codes
P0705
P0711
P0712
P0713
P0717
P0722
P0729
P0748
P0751
P0756
P0761
P0766
P0776
P0778
P0781
P0894
P0973
P0974
P0976
P0977
P0979
P0980
P0982
P0983
P0985
P0986
P2714
P2716
P2742
P2743
P2757
P2759
P2772
[Polls]
What GX 460 trim do you have?
Registered location in US state/territory or Canadian province of your GX
Adjustable Suspension Setting - What mode do you most commonly keep it in?
Who has 10-19 Driver Support Package?
Which mode for Pedal Commander?
Exterior Color
Model Year
[Accessories & OEM Installation Guides]
2013 Accessory Application Chart
2017 Lexus SUV Accessories
2018 Lexus SUV Accessories
2019 Lexus SUV Accessories
Bike Rack
Crossbar Installation
Exhaust Tip Installation
Glass Break Sensor Owner's Guide (2010-2019)
Remote Engine Starter Owner's Guide (2010-2015)
Remote Engine Starter Plus Owner's Guide (2010-2015)
Russian 2010-2013 Catalog
Russia 2015 Catalog
Russian 2020 catalog
[Brochures-Canada]
2011
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Brochures-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2020 (Puerto Rico)
2021
2022
[Brochure-World-outside of US/Canada]
2012 GX 460 Service/Maintenance Schedule Russia
2014 GX 460 Russia
2017 GX 400 China
2018 GX 460 Oman
2019 GX 460 Bolivia
2019 GX 460 Costa Rica
2019 GX 460 Philippines
2019 GX 460 Russia
2019 GX 460 UAE
2019 GX 460 Vietnam
2020 GX 460 Kazakhstan
2020 GX 460 Russia
2020 GX 460 Vietnam
[Multimedia Owner's Guides-USA]
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Navigation/Owner's Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Navigation/Owner's Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Owner's Manuals-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Owner's Manuals-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Personalized Settings ]
2010-2013 (without navigation)
2010-2013 (with navigation)
2014-2017
2018-2019
2020-2021
2022
[Product Info-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Quick Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Quick Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Specification Sheets-Canda]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Specification Sheets-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Warranty/Service Guides-Canada]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Warranty/Service Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
ABS Sensor Wires
Alignment
Alternator
Axle Seal
Ball Joints
Block Heater
Brake Pads - Front
Brake Pads - Rear
Bumper/Fender Gap
Cup holders
Door Lock Actuator
Door Lock Q&A
EGR Valve Removal
Fan clutch
Fuel Pump
Fuses
Head gasket
Headlight aiming
Headliner Removal
Hub replacement
HVAC -Odors
Jack Points
Lean (KDSS)
Oil & Filter change
Oxygen (O2) Sensors
PCV valve
Power Window Issues
Rain Sensor
Rotors
Seat Belts
Seat Heater - Front
Shark Fin Repair
Shifter - Squeaky
Spoiler - oxidized
Starter Replacement
Sunroof Seal
Thermostat
Timing Issues
Tire Rotation
Undercoating
Used/Recycled Parts
V-belt replacement
Vibration issues
Wind Noise
Windshield
Wiper blade refills
[Modifications]
Air Horn
Amazon Alexa
Android Auto
Apple CarPlay
Breathers
Bumpers-overlanding
Canvasback
Captain’s Chairs
Car Cover
Cargo carriers
Cargo Mats
Chrome Delete
Console Vault
Crossbars
Cup holders
Debadging
Digital Speedometer
Door Edge Guards
Door Moldings
Drawers
Drink Holder Insert
Efficiency (fuel)
EGR delete
Fender Flares
Fog Light - Rear
Forced Induction
Hail Protection
Headlight washers
Hitch Install-OEM
Hidden Tricks
Hidden Winch Mount
HUD
Invisacord install
LED conversions
Leveling kits
Lifted
Lockers
Magnaflow
Mirrors - Towing
Pedal Commander
Phone/Tablet mounts
Radar detector
Rear Door Ladders
Rear Door Tables
Recovery Gear
Roof rack/bars
Roof Rail Delete
Roof Rails Upgrade
Seat Covers
Seat Reconditioning
Side Windows Shades
Subwoofers
Tint
Tuning - Engine
Turn Signals - LED
Scangauge
Skid Plates/Sliders
Soft close latches
Spacers
Speakers
Timbren
TPMS Delete
Vinyl Wraps
Washer pumps
Windshield Shades
Techstream
[Firmware]
[Info]
3rd Gen Discussion
Amplifier location
Body Dimensions
Commercials
Cross Shopping
ECO Mode/Light
ETCS-i overview
Extended Warranty
Highest Mileage
KDSS Overview
MPG Discussion
Reviews
RCSA button
Roadside Assistance
VIN Locations
Voice commands
[OBD Codes]
P006A - EGR Valve
Transmission Codes
P0705
P0711
P0712
P0713
P0717
P0722
P0729
P0748
P0751
P0756
P0761
P0766
P0776
P0778
P0781
P0894
P0973
P0974
P0976
P0977
P0979
P0980
P0982
P0983
P0985
P0986
P2714
P2716
P2742
P2743
P2757
P2759
P2772
[Polls]
Exterior Color
Model Year
Bike Rack
Russia 2015 Catalog
[Brochures-Canada]
2011
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Brochures-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2020 (Puerto Rico)
2021
2022
2014 GX 460 Russia
2017 GX 400 China
2018 GX 460 Oman
2019 GX 460 Bolivia
2019 GX 460 Russia
2019 GX 460 UAE
2019 GX 460 Vietnam
2020 GX 460 Russia
2020 GX 460 Vietnam
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2014-2017
2018-2019
2020-2021
2022
[Product Info-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
[Quick Guides-USA]
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
2010
2011
2012
2013
2014
2015
2016
2017
2018
2019
2020
2021
2022
The following 18 users liked this post by Acrad:
bpddaddy (09-07-20),
DaveGS4 (04-29-20),
Dazed (03-29-20),
deadhead1 (08-26-20),
DrumsNstuff (06-24-24),
and 13 others liked this post.
Super Moderator
I will move these up above once there is some form of clear resolution.
Unresolved Issues:
Malfunctioning Touch Screen
Rattle Front End
Sunroof Malfunctioning
Tilt Steering not working intermittently
Added resistor link to Tesla/Tablet entry in first post.
Unresolved Issues:
Rattle Front End
Super Moderator
