Used Purchase/Shopping Questions & Discussions - CPO / Dealers / Private Party
#61
Super Moderator
These threads seem to be some of the primary issues.
https://www.clublexus.com/forums/gx-...50k-miles.html
https://www.clublexus.com/forums/gx-...y-expires.html
460 Price Trends
What to look for if buying a used GX
460 Price Trends
#63
Hi all,
I am new here and please pardon me if I am breaking any rules by posting here. I really needed advice urgently.
I am about to pull the trigger on the following 2015 GX460. What ya'll pros think about it? Should I go for it?
http://driversselect.com/Used-2015-L...TX/vd/48214334
Thanks for help in advance.
#64
That is the lowest price for a very low mile '15 I've seen, even for a Base model.
You can sign up for an account here
https://secure.drivers.lexus.com/lexusdrivers/home
then put in the VIN number and hopefully see the service history if it has been serviced at Lexus dealer. It also give you an idea where the car was originally bought from (flood states etc...)
Karachi (01-09-18)
#65
Thanks for your input. Driver Select only sells 3 years old, 1 owner and under 30K miles vehicles. Here is the carfax report they have provided. Its a Florida Vehicle.
https://www.carfax.com/VehicleHistor...&partner=VSR_0
#66
So I ran it through lexus site and looks like it has alot shaking issues complained to the dealer. It was put up for auction in 9/2017
VIN: JTJBM7FX4F5117373
Filter History By Year
ALL ALL 2017 2016 2015
23779 MILES
DATE: 09/18/2017
REPAIR# 0518456
REPORTED BY:
SERVICE: DETAIL (TRKS)
DESCRIPTION: COMPLETE DETAIL SUV: ~ ~ ~ ~PERFORMED DETAIL
SERVICE: LUBE, OIL & FILTER
DESCRIPTION: LUBE, OIL AND FILTER CHANGE ~ ~ ~ ~
SERVICE: USED CAR INSP.
DESCRIPTION: USED CAR INSPECTION ~ ~AUCTION:ORLANDO ~ ~
14897 MILES
DATE: 06/09/2016
REPAIR# 0382583
REPORTED BY: Lexus of West Kendall
SERVICE: FRONT AXLE
DESCRIPTION: FRONT AXLE ~ ~VEHICLE HAS A KNOCKING WHEN GOING TO BUMPS. ~ ~
~ ~FOUND AFTERMARKET SPEAKERS INSTALLED IN FRONT DOORS. AFTERMARKET
SPEAKERS WERE INSTALLED LOOSELY IN DOOR CAVITY. THIS IS NOT A WARRANTABLE
CONCERN.
SERVICE: NAVIGATION COMPUTER
DESCRIPTION: NAVIGATION COMPUTER ~ ~NAVIGATION NOT WORKING,. ~ ~NAV RESET
~ ~NAV RESET OP CODE 866991 .30
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~PASSSANGER SIDE REAR SEAT
DOES NOT FOLD DOWN WHEN USING THE TOP LEVER. ~ ~FOUND GLASS CONTAINER
LODGED UNDER CABLE THAT OPERATES THE FOLDING OPERATION OF SEAT.
~ ~NECESSARY TO DISASSEMBLE MIDDLE PASSENGER SEAT TO REMOVE CONTAINER
AND RE SECURE CABLE. THIS IS NOT A WARRANTABLE CONCERN.
12870 MILES
DATE: 05/12/2016
REPAIR# 0368709
SERVICE: STEERING WHL/MAIN SHAFT
DESCRIPTION: STEERING WHL/MAIN SHAFT ~ ~CUST STATES STEERING VIBRATE AT 40
MPH AND UP , (CUST BRING VEHICLE WITH PSI VALVES INSTALLED) ~ ~ ~ ~BALANCED
ALL 4 TIRES AND CHECKED FOR EXCESSIVE ROAD FORCE. LEFT FRONT TIRE HAD 4LBS,
RIGHT FRONT HAD 15LBS, REAR TIRES HAD 18LBS AND 19LBS. ROAD FORCE VARIATION IS
UNDER LIMIT BUT IDEALLY TIRES SHOULD HAVE LESS THAN 10LBS. EXCESSIVE ROAD
FORCE VARIATION C
12712 MILES
DATE: 05/11/2016
REPAIR# 0367162
DESCRIPTION: STEERING WHL/MAIN SHAFT ~ ~CUST STATES STEERING VIBRATION AT 40
MPH AND UP ~ ~TECH FOUND ALL TPS SENSOR ARE MISSING IN ALL WHEELS, CALL
CUST , CANT EXPLAIN CLEARLY WHY SENSORS ARE NOT PLACED IN THE WHEELS , CUST
STATES CAR HAS BEEN DRIVING WITH 20' RIMS.CANT DUPLICATE CONSERN AT THIS
TIME. NO CHARGE AT THIS TIME CUST COURTESY ONE T
12306 MILES
DATE: 05/05/2016
REPAIR# 0365192
REPORTED BY: Lexus of Kendall
SERVICE: WHEEL/TIRE CONCERN
DESCRIPTION: WHEEL/TIRE CONCERN ~ ~ ~ ~ ~ ~PERFORMED HIGH SPEED BALANCE NO
FURTHER VIBRATION FOUND
12307 MILES
DATE: 05/03/2016
REPAIR# 0364301
SERVICE: FRONT AXLE
DESCRIPTION: FRONT AXLE ~ ~C/S HIS SUSPENSION FEELS ROUGH WHEN DRIVING AS IF
VEHICLE HAS A BLOWN SUSPENSION ~ ~PERFORMED INSPECTION SUSPENSION HAS NO
ISSUES NO LEAKS WORKING TO SPECS ~ ~NO REPAIRS REQUIRED AT THIS PRESENT TIME
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~ ~LUBE OIL AND FILTER CKECK
AND ADJUST FLUID LEVELS. CHECK AND ADJUST TIRE PRESSURE. ~ ~SCHEDULED
MAINTENANCE ~ ~CHANGED OIL, REPLACED FILTER
DESCRIPTION: WHEEL/TIRE CONCERN ~ ~C/S AT HIGHER SPEEDS HIS STEERING WHEEL IS
SHAKING MAINLY AT 65 T 80 MPH ~ ~ ~ ~ADVISED CUSTOMER TIRES NEED BALANCING
8001 MILES
DATE: 03/22/2016
REPAIR# 0340477
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~C/S HE HAS VIBRATION WHEN HIGH SPEED BRAKING ~ ~FRONT
AND REAR ROTORS OUT OF RUN OUT SPECS ~ ~RESURFACED ALL ROTORS TEST DROVE
VEHICLE 10 MILES AND NO AAAAAAAAAAAAAAA
SERVICE: R. DSC 1-SD (OFF-VEH)
DESCRIPTION: R. DSC 1-SD (OFF-VEH) ~ ~CUSTOMER STATES HIS VEHICLE VIBRATES WHEN
BRAKING ~ ~REAR ROTORS HAVE RUN OUT OUT OF SPECS ~ ~RESURFACED REAR
ROTORS.....473065A 2.3
7978 MILES
DATE: 03/15/2016
REPAIR# 0339555
SERVICE: 10,000 MILE FULL SERVICE
DESCRIPTION: 10,000 MILE FULL SERVICE ~ ~WARRANTY 10,000 MILE SERVICE
~ ~SCHEDULE MAINTENANCE DUE TO TIME OR MILEAGE WARRANTY OP CODE 00110F
~ ~REPLACE ENGINE OIL AND FILTER, ROTATE TIRES, ADJUST TIRE PRESSURE, RESET
MAINTENANCE LIGHT, INSPECT ENGINE AIR FILTER, CHECK ALL FLUIDS, INSPECT BRAKE
PADS LININGS & DISC ROTORS. INSPECT DRIVE BELT AND RADIATOR HOSES.
COMPLEMENTARY CAR WASH.
SERVICE: FRONT/REAR BODY
DESCRIPTION: FRONT/REAR BODY ~ ~C/S HIS TWO REAR DOOR CHILD SAFETY LOCK DO
NOT RELEASE ~ ~REAR DOOR LOCK LH RH REAR INTERNAL FALIER ~ ~REMOVE BOTH
REAR DOOR PANELS AND REPLACE BOTH REAR DOOR LOCK ACTUATOR. 672121 0.6 L/R
672121 0.6 R/R
SERVICE: OTHERS
DESCRIPTION: OTHERS ~ ~C/S WHEN HE BRAKES AT HIGHER SPEED BRAKING HIS
STEERING WHEEL SHAKES ~ ~CALIPERS HAVE BEEN PAINTED ~ ~NEEDS TO RESURFACE
ROTORS...
10 MILES
DATE: 07/08/2015
REPAIR# 0216215
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PDI ~ ~ ~ ~DONE
23779 MILES
DATE: 09/18/2017
REPAIR# 0518456
REPORTED BY:
14897 MILES
DATE: 06/09/2016
REPAIR# 0382583
SERVICE: FRONT AXLE
CONCERN.
12870 MILES
DATE: 05/12/2016
REPAIR# 0368709
FORCE VARIATION C
12712 MILES
DATE: 05/11/2016
REPAIR# 0367162
12306 MILES
DATE: 05/05/2016
REPAIR# 0365192
12307 MILES
DATE: 05/03/2016
REPAIR# 0364301
SERVICE: FRONT AXLE
8001 MILES
DATE: 03/22/2016
REPAIR# 0340477
SERVICE: OTHERS
7978 MILES
DATE: 03/15/2016
REPAIR# 0339555
672121 0.6 R/R
SERVICE: OTHERS
ROTORS...
10 MILES
DATE: 07/08/2015
REPAIR# 0216215
Karachi (01-09-18)
#68
Looks like most of the "Shakings" complaints are due to the aftermarket 20" Rims / tires NOT balanced well. If it drives WELL then I think that is a good buy.
3 months ago my brother bought a base '14 (with navi and premium audio) - same specs as this '15 for $38.9k with 26k miles. It is Lexus Certified, though.
#70
Maybe ask the dealer to swap out the 20’s with stock 18’s and test
Karachi (01-09-18)
#71
Do you think its worth the hassle? Shouldn't I spend a few thousand dollars more and get a car with clean history?
Forgive me for my ignorance, can you please direct me to where I can put the VIN to pull the service history on Lexus Owner's site?
Really appreciate ya'll help.
#72
You can go to the link I posted and sign up for an account.
Once you got it, log in, then click on the top right Account->Manage Your Lexus Vehicle. Input the VIN of the vehicle you want to check. Then click Manage this Vehicle.
Then on the top, click Resource->Service->Service History.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/445x425/screen_shot_2018_01_09_at_12_14_55_pm_76f9faad74a9aca167d7600d0977625049b57868.png)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/597x354/screen_shot_2018_01_09_at_12_13_46_pm_ddbb55908c155f15c3a7b8c904a74e1fe103fd44.png)
Karachi (01-09-18)
#74
From the listing, it looks like the car has the stock 18" wheels /tires. Maybe either the dealership or previous owner swapped out the aftermarket 20" wheels / tires before listing it for sale ?!? I would defintely buy this car if i'm in a market for one.
Karachi (01-10-18)
#75
Any thing other than the price and mileage that is enticing?
