With Rear Suspension Airbags Fully Inflated, How Much Ground Clearance?
For those with airbag suspension, how much ground clearance are you getting with the bags fully inflated?
Remember, the air suspension is on top of the rear live axle. And GX is body on frame structure. No matter what setting, it didn’t change any ground clearance. The bottom of rear axle has never moved up and down. The air suspend only changes load floor and roof heights.
nuclearn8 (04-05-20)
Raising the rear causes the front to tilt down slightly, causing your minimum ground clearance to actually decrease a bit. You can see it a bit in
Yup, the approach angle will be slightly less and the departure angle will be greater in the highest setting.
Thanks to Arcad:
https://www.clublexus.com/forums/gx-...breakover.html
Some huge 37”s should increase that ground clearance for ya!
Thanks to Arcad:
Thanks to Arcad:
Thanks to Arcad:
Mostly a hilarious joke...
So to answer this another way ... the airbag system is not designed to increase ground clearance, it’s purpose is to re-level the rear end when carrying a heavy load ... cargo, rear passengers or when towing (or a combination thereof). Only taller tires will increase ground clearance.
mlinn1967
Suspension
08-08-16 06:50 PM
Fastphil
Suspension and Brakes
07-25-05 10:51 AM
