Pod Lights
Pod Lights
I ordered pod lights on Amazon today. Now I need a few things to complete the install, I need an OEM style switch that will fit in the blanks to the left of the steering wheel.
The ones that look like this:
Except mine has like 3 of those blank.
I found two sites that have "toyota oem style" switch. But none specify 2013 GX460 or even Prado.
TOYOTA OEM STYLE "DITCH LIGHTS" SWITCH $14.99
https://caliraisedled.com/collection...-lights-switch
CH4X4 Custom Laser-Etched Toyota Push Switches $26.98
https://www.ch4x4.com/product/ch4x4-...push-switches/
I also need the mount, I have only found two and they both seem very overpriced for what they are. Is there cheaper alternatives?
2010-2020 LEXUS GX 460 LOW PROFILE LED DITCH LIGHT MOUNTING BRACKETS $54.99
https://caliraisedled.com/products/2...nting-brackets
2010-2019 2ND GEN LEXUS GX460 DITCH LIGHT BRACKETS $84.95
https://www.ragofabrication.com/prod...light-brackets
Amazon has a few from $20-35, for the tacos and T4R's.
Lastly, I would need a wiring harness.
So far I found this one for $10. Except I would like to replace the switch with an OEM style, not sure I could do that.
Any help is appreciated.
Just wanted to share an update with the board, I ordered both sets of mounts and they both will work. However there is a significant difference in the thickness of the material used.
I took some photos to share. The thinner one is the Amazon brackets for the .
The thicker one is the one from caliraised.
Also note the Caliraised would be lower profile when installed.
I remember reading somewhere the taco brackets don’t work on the 460.
Did you figure out your Wiring and switches?
My car is the base system. Yes I am upgrading the speakers along with adding the subs.
Here is the list:
Front Doors: JL Audio C2-690tx 6x9
+ Rockford Tweeters
Rear Doors: Pioneers
Dash Speakers: 3.5"
I have two amps going in from JL Audio. 1000 watts each.
I'll do a more detailed post when it's all in.
Here is the list:
+ Rockford Tweeters
Dash Speakers: 3.5"
Super Moderator
In most states, having lights above the main headlight level is illegal unless they are considered accent lights that are below a specific level of light output (FJ Cruiser as an example). Even if not in use, some states require that they have covers installed with the covers removed only for off-road purpose. I do not worry about such things, but ...
Beyond that, what problem are these trying to solve ?
NancyJade
04-22-18 10:50 PM
bobinsofla
GX - 1st Gen (2003-2009)
11-12-08 10:53 AM
