GX460 - Tire Size Comparison Thread
#31
Your're correct! I tried to delete my prior post on this thread, but deleting is disabled. Should I just delete all of the text?
Thanks for keeping the info current.
#33
Not sure if this utility has been share before but it is an awesome way to see the exact dimensions of any given tire vs. another.
https://www.tacomaworld.com/tirecalc...0r17-255-75r17
#34
Piney1 (11-30-20)
#36
What DRIVES ME CRAZY is all this energy to showcase various tire sizes ... with ABSOLUTELY no wheel reference when running non-OEM wheels. Without knowing the Wheel Width and Wheel Offset and Lift (if applicable), proclaiming "no rubbing" for a given tire size is totally worthless information.
chopperpl (02-28-23)
#37
The point of this thread is not to describe every wheel / tire / offset and possible combination that would fit a GX460, but rather tire sizes using ONLY stock wheels and stock suspension. This was outlined in the opening thread.
I agree though, without specifics on wheel / tire size / suspension its useless to begin a discussion on the topic. This being said in keeping with my opening statement of Stock Suspension / Wheels the claims of "no rubbing" are perfectly valid as each vehicle I listed above are following these two critical protocols!
I will add the wheel and offset info to the thread of a stock wheel though!
Thanks!
BamBamSr (12-28-23)
#38
Kenda Klever LT275 70 18 will these fit on stock 2013 (w/ stock wheels) with some trimming? I don't want to BMC they have 33.43 diameter
I plan on doing Dobinson or Ironman lift but it will be spring or summer before this is done and my tires are shot now.
I want to go as big as I can so they look OK when lift is done. Or do you think I have to go with LT275 65 18 a 32.32 diameter??
#39
#40
see post #1: member desioc has that size, needs some trimming of the fender to to fit!
#43
#44
I bought them (and pretty much every tire the past 10 years) from Discount Tire Direct, happened to buy them on a 100 dollars off 4 tires day, I believe they came out to around 150 a tire plus around 150 to install.
#45
I believe this particular rig is a 2020 (Lexus removed the door trim from 2020's and beyond) I agree though looks very clean without the door trim!
