TRD pro wheels vs stock
Some of the TRD Pro wheels actually have BBS FORGED stamped on them as well.
I only know of one forged manufactured TRD wheel that would probably fit the GX and that is the "Rock Warrior".
https://www.toyotapartsdeal.com/oem/...r45-35010.html
Agree ... but with the "standard issue" Toyota 7.5" Width and +6mm Offset .... WHY is Toyota so married to these specs ??? ... better 8.0" or 8.5" Width and -6mm Offset. TRD wheels with a "Soccer Mom Stance" is an oxymoron, which is exactly why many go with TRD clone wheels.
27.3 pounds based on this tacomaworld forum thread: https://www.tacomaworld.com/threads/...s-ko2s.381030/
Hey folks, reviving this one from the grave. What is the true offset of stock GX wheels, at least for 2020+ MY? I looked at mine, and saw both a 52 (or 53), and a 25 stamped on the inside of the spokes. Neither of these numbers were prefixed with "EJ" and there seems a level of uncertainty on here also.
My go-to online sources indicate 25mm, whereas others are also in the 5xmm range. So which is it? I was about to pull the trigger on TRD replicas for my winter set, but the CS rep advised against it given the drastic difference of +5mm to +5xmm.
2chains (08-14-21)
EZZ
09-30-20 07:12 PM
