2015 Lexus GX 460 chaging left side mirror signal lamp
hi! everyone! i have a 2015 Lexus GX 460... anyone know how to remove the left mirror housing? my signal light got broke. i want to change it. i've been searching and nothing to find. any help please... thank you and God Bless
1. Remove the door panel, there is two bolts, one behind door release handle and other behind arm rest. Rest of are held by clips.
2. Take the small triangle piece where you will see three bolts hold the mirror housing.
3. Disconnect the mirror harness
4. After take the mirror off, you will need to remove the mirror glass, then mirror cover which is all held by clips. There are few video clips on YouTube that you could reference.
5. Then you will be able to access the turn signal light.
The most difficult part is remove the mirror cover. Be patient and take time. There are six or seven clips and it is easy to break if goes the wrong way. Using two small felt head screw drivers will make it a bit easier.
Good luck.
You may get a way doing it while it is attached to the door. But given the way that you have to remove the glass and cover, it is much easier when it is off the door and give you more space and flexibility to work with. As I said, remove from the door is the easy part.
update... i just did it today 10/21/20. everything went well nothing broken. thank God. i take my time to remove the mirror and pry the hook. i used Pittsburgh Automotive ( Nylon Pry Bar Installer Kit, 4 pc) and one flat head. the only thing that i got struggle is to remove the two wire. everything else is good. hopefully someone well help this post in the future. God Bless Everyone...
dimpasa
09-08-23 10:39 AM
