Recalls on 14+ GX460
What recalls are applied to the 2014 GX460? I believe I remember there was a fuel pump recall. I think I am experienced a failed fuel pump at the moment. Car would not start and seem to be fuel related.
Super Moderator
Model years 2014-2015
2014 through mid February 2015 460's are on fuel pump recall
https://www.clublexus.com/forums/gx-...mp-recall.html
Acrad (10-19-20)
Enter your VIN here to see if you are part of the recall: https://www.toyota.com/recall
Super Moderator
I thought I remember you had a Luxury and put a lift on removing AVS shocks? If so, I think those suspension codes might always be there for missing AVS shocks when you scan for codes.
Do you still have the knock sensor code number?
I cleared the codes before I wrote them down. I only remembered the one related to the fuel pump as it was what i suspected as the problem. Yeah, the suspension codes are expected. do you happen to know if the recall actually replace the fuel pump or just the orings as some member stated?
jimbug
NX - 1st Gen (2015-2021)
15
09-17-20 08:54 AM
