Illuminated overhead sunroof buttons?
Hey guys,
I've just realized that the buttons for open/close/tilt sunroof are not illuminated at night in my 2020. Also the memory seat buttons are not either ( I pressed the wrong one a couple of time and it ended up saving the wrong seat settings LOL)
Is it normal on the GX? Just want to make sure they didn't forget to put in a fuse at delivery :P
should be on the left side of the wheel.
hadokenuh (10-29-20)
@WRD4chano yeah, that button only controls the brightness of the ODO.
I am asking specifically the sunroof and memory seat buttons. Are yours illuminated at night or not?
Haven’t thought about the needs to hack them, nor it is practical. For illumination, it will need the button had space behind it to host LED and most difficult to have the transparent marking rather solid paint marks as it is now. One option that you could consider (if that is something you had to have), is to tap a small hole in adjacent area to host a LED and wire into the windows/door lock switch panel backlights, and do the same on sunroof switch area, and wire it into top accent LED.
hadokenuh (10-30-20)
peterGX470
GX - 1st Gen (2003-2009)
11-27-05 10:45 AM
