Instrument Cluster Removal & Disassembly
Reviving this discussion. @TaninAuto can an amateur remove and reinsert the cluster needles on the GX460 gauge without causing calibration issues? The second video @Acrad posted above gives me an idea for a way to cover up a flashing AFS light for a non-OEM headlight replacement if I can be relatively sure I wont screw up the cluster doing it.
Thanks I've learned a ton from you guys
rip into that to disable a light?
should be able to send the correct signal at the harness
We would not recommend anyone to disassemble their own clusters and try to calibrate needles.
Especially with the inflating cost of parts and the decreasing number of suppliers that have them, it's just not a risk I would take.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
it's-gettin-old
12-15-01 02:33 AM
