Subwoofer?
Old 03-04-22, 10:29 PM
  #31
esonu
esonu's Avatar
Well I ended up getting the pac harness and running the wiring to the driver side under the seat. Everything came out good but there’s a problem which seems like it’s from the ground. On my line output converter there is a ground wire and I’m attaching it the the passenger side where the pac harness is. When it’s connected I get no sound from any speaker. Once I remove it all speakers work except the subwoofer as the loc doesn’t work. Any info on this? Do I need to run the ground to the front?
Old 03-04-22, 10:31 PM
  #32
esonu
esonu's Avatar
I forgot to add that when I connect the ground after the speakers are working then the loc turns on and the subwoofer works but if I turn off the car and then it back on no sound.
Old 03-07-22, 12:09 PM
  #33
markdh
markdh's Avatar
Have you tried just grounding to the chassis (bare metal)?
Old 03-06-23, 11:39 AM
  #34
galante
1st Gear
galante's Avatar
Originally Posted by esonu
So I’ve been going through the speaker thread and can’t find anyone doing real subwoofer installs. I was wondering if anyone has mounted the amp in a location that can’t be seen and is out the way of anything. I want to put a subwoofer in but I want to be able to remove the box if needed for traveling or just if I need the trunk space. I want to mount the amp somewhere where it won’t affect anything and won’t get in the way, but can’t figure out where would be the best location.
Does anyone know if there’s space behind the back panel where the AC plug is so I can mount the amp there. Thanks in advance.
Local shop said they wanted to mount it all the way in the passenger rear section under the molding (?). They said they'd have to remove the seats, so the install for a $550 amp was going to be $550 due to the extra time.
Old 03-06-23, 02:17 PM
  #35
xStayTuned
xStayTuned's Avatar
So since i have ML would i be able to just replace the factory sub with another shallow mount 10", and run that from my aftermarket amp using the L2Ci Pro from the factory wiring?
Old 07-23-23, 09:00 AM
  #36
MNLexGx60
2nd gear
MNLexGx60's Avatar
Yes you can do this, I had a 2012 Range Rover Sport which I did the same thing. Just make sure you measure the depth of the subwoofer if you're installing in the same location as the factory sub.
Old 04-09-24, 02:01 AM
  #37
alexxfld
1st Gear
alexxfld's Avatar
Originally Posted by markdh
I purchased a Mark Levinson subwoofer box from a junkyard. Crutchfield.com showed that Pioneer TS-D10LS4 D-Series 10" 4-ohm shallow-mount subwoofer at Crutchfield would fit in factory sub box. The subwoofer fit great! Only modification required was drilling new holes for the screws. I am very happy with the results and just wanted to pass along an option for others. Hopefully in the next couple of months I can build a grill to clean things up a bit.
Looks awesome! Did you connect it to the original electrical connections from the oem speaker?
mine is a ML system with the box included
but is seems that the original connection is different from the aftermarket speaker you’ve installed
thanks in advance
Old 04-09-24, 04:56 AM
  #38
bootman
bootman's Avatar
This video may give you some ideas.
Boomin (04-11-24)
Old 04-10-24, 02:35 PM
  #39
markdh
markdh's Avatar
thanks in advance
No, I don't have Mark Levinson system, so I have an aftermarket amp and ran wires from amp to subwoofer.
egomambo
11-02-21 02:31 AM
Soarer2
RC F (2015-present)
11-26-20 08:59 AM
Tantrix
08-31-16 06:20 AM
ttiangco
06-18-11 04:03 PM
PDG810810
08-15-06 09:27 AM
Quick Reply: Subwoofer?
