noises on cold start up
[UPDATE]
Had an opportunity to hear another GX do a cold start up and the sound was identical. It's fan clutch, plus valve train sound.
No, it’s not normal. Cold start clatter is cause by lack of lubricant or oil being circulated. Metal to metal contact most likely cause by carbon / sludge in the engine preventing lubrication. Up to 90% of engine wear comes from cold starts and yours sounds particularly bad.
I use MMO to clean the engine in all my vehicles for years now. Also works for the fuel system. You can also try using an engine flush but I personally like MMO better. It does a more thorough job. You run it with the oil for usually 500 miles or so and then change the oil. You need to clean the internals. I would suggest running a quart of the product. Don’t overfill the oil! Extract or drain a quart of oil before adding MMO. Walmart sells it for like $4 a quart.
Also, what oil are you running? Should be at least a 5w fully synthetic in cold climates. Cold start clatter manifest more in particularly cold climates because cold oil takes longer to circulate. If you are interested in additional protection I also suggest checking Cera Tec by Liqui Moly. Another product that I particularly love. You can find it on Amazon. My engines start with zero clatter even on the coldest days.
RockyMtnLo (01-02-21)
This video is about ten seconds into a cold start. I was concerned about the audio not catching it, but the sound seems to be coming across loud and clear, if not a little better than my own ears.
https://myfamilymylife.smugmug.com/M...shbS/i-RZXmnSF
I’ll make a video of my engine tomorrow morning for you to hear the difference. I seriously think it is lack of lubrication due to carbon preventing proper oil flow to the upper valve train.
RockyMtnLo (01-03-21)
Here you go, I made it this evening as the temps are actually supposed to be about 6 degrees warmer in the morning. Temp on outside thermometer said 36, vehicle read 37 degrees.
Truck has been sitting for 2 days as it’s not my daily. I’m currently running Mobile 1 EP 0W-20. Cleaned the engine with MMO as mentioned when I received the vehicle about 5 months ago and changed the oil after about 500 miles of driving. Then treated with Cera Tek by Liqui Moly. Cera Tek product is amazing. Best thing since sliced bread for cold start protection among other things. I use in all my vehicles. As you can see / hear my engine is much more quiet than yours. It’s not magic...
The following 3 users liked this post by Lavrishevo:
I’ve had several Toyota 4.7s and one 5.7. The 4.6 on my 2012 is my first.
It may just be a characteristic of this engine, but the start up sequence and warm up is really different from what I am used to.
When cold, it’s very loud the first 2-4 minutes and I’m not talking about exhaust. Sometimes there’s a knocking sound for 30 seconds or so that almost sounds like a far away jackhammer or a fan grazing the shroud (it’s not that, but sounds similar).
I really like the gx and after warming up, the engine is quiet and smooth. This one has 44k mile on it and full Lexus service history’s. It was babied.
This phenomenon seems to manifest more in the cold. We’ve had some single digit weather lately and I’ve noticed it more.
Is this normal?
Is this normal?
The following 2 users liked this post by ASE:
Acrad (01-04-21),
Lavrishevo (01-04-21)
