The AC keeps cycling on and off and I'm suspecting it's the evaporator temperature switch also called the thermistor. How difficult is this to access? Do I need to remove the navigation unit?
I followed the procedure and there are no hvac codes.
Not sure this is the same thermistor. I was under the impression the thermistor is on the evaporator box and measures temperature of inlet air at the evaporator.
Thank you for posting the diagram. The thermistor is only $20 and I have one on order. Tearing into the dash doesn't look difficult. I can let you know how it goes.
