My gx460 2014 do this some time
Check your YouTube link please. I played with it and the only thing I can find is that it is "Private".
I think we have some mechanics here that can help with that sound. If I recall correctly, the starter is not an easy job on this rig.
Super Moderator
Unfortunately it could be a lot of things
Is it consistent?
Is it consistent?
sounds like the starter pinion gear engages, then disengages, then re-engages the flywheel.
i didnt read this entire doc, but it does explain how this works.
http://autoshop101.com/forms/h7.pdf
look at the tests on p15, could probably perform those on the vehicle with the wiring (as long as you know what youre doing). Should be able to hear it.
