Something went terribly wrong when installing ARB Compressor.
*sigh*
Hey guys, I was hoping my first post wouldn’t be troubleshooting a screw up but here it is.
When I finished installing my ARB Compressor everything seemed to work fine. The switch would light up and the compressor would turn on. Red/yellow tapped into P/OUTLET slot and blue tapped into PANEL.
However, when I went to start the vehicle it whirred but didn’t turn over. A soft whir was heard when it was shut down so I unhooked the battery to make it stop. That stopped it. Upset, because I must’ve gotten it wrong; I then disconnected the tapped in fuses and replaced the fuses in their rightful spots. I unplugged the compressor and the switch to see if the GX would start but I still get the same whirring.
Any help would be greatly appreciated! I just picked up this vehicle last month. 2018 GX460 with 25k miles.
Does your battery have enough charge? Can you hook it to a jumpstarter and try again?
ltsr (02-13-21)
I was installing accessories and had the door open for a while and I drained the battery enough that somehow the high beams started flashing on its own. I tried starting the car and it didn’t start. I hooked up a jumper pack and it started up with no issues. Try jumping it.
Nefarioc (02-13-21)
Charged and cranked yet?
eburggx470 (02-15-21)
MZjr
RX - 3rd Gen (2010-2015)
04-20-23 08:53 AM
