Fan clutch questions/concerns/problems
Old 05-09-21, 03:31 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,646 Likes on 2,388 Posts
Here is a good overview of a viscous fan clutch as used in 460
The following 4 users liked this post by Acrad:
DrRock (02-26-23), hzhao (05-09-21), sinistar (05-12-21), texas008 (02-20-24)
Old 05-09-21, 04:58 AM
GroguGX460
GroguGX460's Avatar
https://www.youtube.com/watch?v=UwM4OqsLek4
how do you know when it’s failing or operating incorrectly? Besides the obvious overheating (which it isn’t doing). I assume on a 2017 it’s not as likely? But I also have 90k miles which is higher.
Old 05-09-21, 06:38 AM
Acrad
Super Moderator
Acrad's Avatar
What I recall is if it freely spins cold it has probably failed and won't allow for cooling .......a good clutch IIRC is only like 1/4 turn when spun by hand cold.
Old 11-09-22, 02:45 PM
angelslex
angelslex's Avatar
Default Fan Clutch
Finally we found the noise that was driving us crazy. We thought it was the rear end or bearings. The sound was traveling to the mid/back section of the truck.
is a Fan Clutch. Anyone else has dine this repair.?
Old 11-09-22, 06:02 PM
Acrad
Super Moderator
Acrad's Avatar
Water pump replacement video is a good resource on fan clutch replacement as well
Post 8
https://www.clublexus.com/forums/gx-...-pump-diy.html
angelslex (11-10-22)
Old 11-10-22, 05:55 AM
angelslex
angelslex's Avatar
Post 8
didn't think of this. Thanks
Old 11-10-22, 06:21 AM
angelslex
angelslex's Avatar
Looks like I can pull this out my self . Radiator cover 3 bolts and the fan 4 bolts. 🤞🏼
Acrad (11-10-22)
Old 11-10-22, 06:56 AM
NewB2Lexus
NewB2Lexus's Avatar
What is wrong with the fan clutch? Are you getting OEM or aftermarket?
Old 11-11-22, 07:33 AM
NewB2Lexus
NewB2Lexus's Avatar
Also I would be interested in what holder tool fits the GX. Does a generic or Toyota specific one fits?
Old 02-25-23, 12:31 PM
Acrad
Super Moderator
Acrad's Avatar
I noticed mine has staying on a lot longer on cold starts for the last 2-3 months or so. I replaced with a new OEM unit this morning and also replaced my drive belt at the same time.
A couple of these long handled wrenches and a long screwdriver and was able to get the fan clutch nuts off (12mm)
Amazon Amazon
I could tell right away on start it fixed it. It settled down to disengaged within a minute... didn't time it. It's a frozen morning and I was having to get it over 2500 RPM or so on cold mornings for it to disengage.
Currently at 79k miles.
Old clutch...
The following 2 users liked this post by Acrad:
bbqsoup (02-28-23), Romanova (02-27-23)
Old 02-27-23, 10:08 AM
Romanova
Romanova's Avatar
Did you go actual OEM or Aisin? Mine is still going strong at 141k, but I bought the Aisin unit to be installed with the water pump and a few other items...
texas008 (02-20-24)
Old 02-27-23, 10:16 AM
Acrad
Super Moderator
Acrad's Avatar
I did go OEM (Aisin)
Romanova (02-27-23)
CharlieH
RX - 1st Gen (1999-2003)
07-22-24 09:47 AM
Jadon
RX - 3rd Gen (2010-2015)
10-26-13 02:59 AM
mroctober7
05-19-11 10:43 AM
MDGS4
11-17-08 08:56 AM
Quick Reply: Fan clutch questions/concerns/problems
