Trailer Brakes
Have zero experience towing. Might rent a small Uhaul 4X8 trailer to haul some stuff on our way back down from the Northeast to TX. Here is the capacity info:
Thanks!
- Volume: up to 142 cu. ft.
- Max load: 1,650 lbs.
- Gross vehicle weight: 2,500 lbs. max.
- Empty weight: 850 lbs.
Thanks!
Super Moderator
IMO: You should be fine. Just make sure you keep extra distance between other cars and lower speeds.
I have a 8 x 10 trailer that weights about that much and has a 3500lb axle with full size wheels. It doesn't have trailer brakes and I haul a load of energy logs every winter that are one ton. I will have to check again but I think GVRW on that trailer is 3000 or 3200 lbs. I haven't looked at that in years.
My state (Washington) only requires them over 3K lbs.
https://drivinglaws.aaa.com/tag/trailer-brakes/
CFAI (05-29-21)
Acrad (05-30-21)
HanaleiISF
12-05-14 03:47 PM
