Can the Upper Control Arm Ball Joint be replaced for the GX460?
I tied finding the parts on the dealer site, but they only offer the full Upper Control Arm set. I don't want to buy the set as it's kind of expensive.
Then I searched AutoZone and they do have the Ball Joints only.
Before buying third-party parts, I am just wondering if it's removable.
I have one set from my 2018 with less than 10k miles on it. I had a lift kit plus aftermarket upper control arms installed. I’ll sell it to you really cheap if you’d like them
That seems like nonsense... Google Toyota LCA replacement and watch the videos. Alignment most install.will be an additional expense... just mark it before removing it and it'll be close enough to drive it to get aligned.
It is BS, but I dont have the tools or place to do it myself.
EDIT - This is normal according to the dealership. Exact words from the service writer "That's the way it is on these vehicles"
Hello all, I got under the truck for the first time today to check things out after a week of ownership and I noticed a wet spot at the top of both (Passenger and driver) suspension knuckles.
The top 4 inches or so of each knuckle is wet, but it's not dripping on the ground or anything. Is this normal for these vehicles? I don't see a grease fitting on the ball joint, so I wouldn't expect leakage, but I thought I would ask the experts here.
Thanks all!
Reason: Update
If the boot isn't torn, it shouldn't be leaking. You said the truck is new to you; was it possibly sprayed by the dealer with some slimy liquid to pretty it up? There's a difference in sheen on a part of the brake line and perhaps even the spring looking at the photos.
Hadn't thought of that. There isn't much space between the brake rotor and the wheel for detailing spray to get through, but I suppose it is possible.
you're fine, took this to the dealer and they said its fine. im going again to two weeks for an oil change and ill ask them to check again. (just noticed i forgot to get a pic of the upper control arms joints)
and the uppers
Reason: added photos of the raggedy upper ball joints
