Engine Area Ticking Noises
Old 11-16-23, 03:28 PM
  #31
IanG
IanG's Avatar
Try to narrow down the location of the noise, if you have a mechanics stethoscope that is ideal, if not you can use a large screwdriver. It could be a leak or cracked exhaust manifold. The first place I would listen would be the valve covers and timing chain covers, it could be tappet noise or timing chain tensioner, also listen to the fuel rails, injectors can be noisy but usually not that loud.
BriHurl (11-16-23)
Old 11-16-23, 03:58 PM
  #32
Received 2,935 Likes on 2,471 Posts
Originally Posted by BriHurl
Could it possibly be a leak in the exhaust manifold maybe??
Maybe. Exhaust manifold leak does sound similar.
mike202 (11-17-23)
Old 11-16-23, 06:26 PM
  #33
arentz07
drives cars
arentz07's Avatar
Received 3,805 Likes on 1,930 Posts
just noticed posted this in the IS forum, sorry
Moved it for ya.
Acrad (11-17-23)
Old 11-17-23, 06:12 AM
  #34
gfcipriani
gfcipriani's Avatar
Sounds like an exhaust leak. But honestly, there are several things it could be, some more or less concerning than others. Have a trusted mechanic check it out. You could also take it to a Toyota dealership and have them check it out. They are usually very competent with lower labor rates than the Lexus mechanics, and there really are not any mechanical systems on the vehicle unique to Lexus.
Acrad (11-17-23)
Old 11-17-23, 07:29 AM
  #35
BriHurl
4th Gear
BriHurl's Avatar
Originally Posted by IanG
Try to narrow down the location of the noise, if you have a mechanics stethoscope that is ideal, if not you can use a large screwdriver. It could be a leak or cracked exhaust manifold. The first place I would listen would be the valve covers and timing chain covers, it could be tappet noise or timing chain tensioner, also listen to the fuel rails, injectors can be noisy but usually not that loud. https://youtu.be/U927cYhQXB4?si=ZyKeRKQUYK74_vSp
Took it to a reputable mechanic yesterday and they threw it on a list and looked around for about an hour and a half, and could not identify exactly what was causing the clicking. They did discover that the car does not have to be in drive for the clicking noise to happen so it’s definitely in the engine. They used the stethoscope and listened all over the place and determined it’s coming from the front part of the oil pan above the oil pan, leading them to believe that it may be tensioner guide or something inside the motor, it seems like it may be catastrophic if it gets worse. To diagnose any further would cost a lot of money because they would have to take the engine out of the car to get to the tensioners. I am super bummed.
Old 11-17-23, 07:34 AM
  #36
gfcipriani
gfcipriani's Avatar
Exhaust leak would also sound different with the vehicle in gear and brake engaged due to the static torque in the drivetrain
Old 11-17-23, 09:55 AM
  #37
CFAI
CFAI's Avatar
If I may ask how much? Also would they apply that charge to the fix if it was in the engine?
Old 11-17-23, 10:04 AM
  #38
mike202
mike202's Avatar
This is not correct. The engine front cover can be removed w/ engine in place. It is a lot of work but engine remains in place.
Here is a video of R&R of the timing cover.
https://www.youtube.com/watch?v=Cm9OfK_nD1w&t=63s
cs191707
RC F (2015-present)
05-21-20 10:19 AM
Dildildil
GX - 2nd Gen (2010-2023)
19
12-17-19 07:22 AM
trombs
GX - 1st Gen (2003-2009)
15
11-04-14 09:30 AM
SecPole14
02-14-14 04:25 AM
uahogs
33
03-03-09 12:51 PM
Quick Reply: Engine Area Ticking Noises
