#Key #Fob - Problems & Questions
Piney1 (06-30-22)
#183
… on the other issue I reported … “Other electrical problems over time (related or not, I don’t know)… sometimes can’t lock/unlock car with key fob but works with door handle and vice versa. And then the next time it works absolutely fine. Sometimes it also says it can’t detect the key fob when switching on or after just switching on. And then it’s fine again.” … has anyone had experience of this or not, as I suspect I will still encounter this from time to time? Thanks
#184
Fob Remote Start is "short distance < '80 and short time < 5 seconds to start.
Phone App RS is "long distance - anywhere with cell service and long time > 15 seconds.
The fob cadence is a bit fussy, would not want to be fiddling is your purse or pocket and RS, right?
Press/release/Press/release/Press and hold till you see the markers flash independently.
Three ways to shut off the Remote Started car: 1) wait 10 minutes, 2) Press and hold the fob lock button long.
3) Open a door. Note: the new Interface setup on the new 2022 NX's and 2022 LX's do Not shut off when the door opens!
Coming soon to each model as they phase into the new Interface generation. (about time...)
#185
Key fob not unlocking , locking the car
I have a 2022 gx and my key fob isn’t unlocking or locking the door by pressing the button. The key fob let’s me get in the car by touching the driver side or passenger side door, and starts up the car just fine. When I stop the car and lock it manually there isn’t any sound at all like before . Anyone have this issue ? What’s the fix ?key fobs will not lock, unlock or trigger the panic alarm. Both have batteries with greater than 3v. Both illuminate the light when a button is pushed. Both will start the car without being held near the push button. No "key not detected" warning.
#186
I have a 2022 gx and my key fob isn’t unlocking or locking the door by pressing the button. The key fob lets me get in the car by touching the driver side or passenger side door, and starts up the car just fine. When I stop the car and lock it manually there isn’t any sound at all like before . Anyone have this issue ? What’s the fix ?key fobs will not lock, unlock or trigger the panic alarm. Both have batteries with greater than 3v. Both illuminate the light when a button is pushed. Both will start the car without being held near the push button. No "key not detected" warning.
#187
Have you check the settings? It should be under Vehicle , then Lock/Unlock section, where you can enable or disable certain key fob function, as well as the light and sound, etc. For 2022, those setting screen and menu items are little different from previous generation GXs. But it should not be difficult to access. Just reference your owner’s manual for detail.
yes I have tried fixing it that way. It still doesn’t work.
#190
Our 22 GX has had a plethora of "key not detected", no unlock/lock, and just overall key issues. Dealer just blames it on poor battery voltage but it happens with new key batteries from them and myself swapping them out. Something is definitely wrong but they do a quick techstream scan on the car see "no issues" and give the car back to us. Frustrating and it's extremely intermittent so I can't get it replicated when we take it back to the dealer. Thankfully it hasn't left us stranded, but it's still extremely annoying and we've gotten nowhere with the dealership.
#191
so you have the same issue ? Mine will start the car , unlock and lock my doors if it’s in my pocket . They don’t unlock or lock if I press the bottom on the key fob. I am taking it to Lexus Thursday . I can update you what they say. But damm I’ll be pissed if it doesn’t get fix . So your Lexus just gives it back to you not fix?
#192
#193
Touch sensors worked and the car would start just fine but the buttons on the 2 FOBS would not work.
The driver-accessible menus DO NOT have any options for this issue.
The dealer needed to put their tablet on the car and correct the menu. We have no idea how the option changed but all is OK now. The dealer handled it under warranty.
I came across a guy on FB where the dealer was not working with him and wanted to charge him as a non-warranty issue. Since there is now a record of this should they hassle you feel free to PM me for the name of the dealer and service rep so that your dealer can contact them directly.
#195
