Key Fob - Problems & Questions
#211
YES! Just like the comment above this one, had to bring to my local dealer and they needed to use diagnostic tool to turn all the settings back to on. For some reason I couldn’t do it on the user interface, nor could he. Only the diagnostic tool the dealer has was able to see it.
#213
I've developed a bizarre issue with my 2010 GX. Typically, when you exit the vehicle with the keys, while the car is running, and close any door, the car will beep...telling you that the key has been removed from a running vehicle. Likewise, if you manually lock all the doors while leaving your key inside, it will automatically unlock when you shut the last door and beep. On my GX, this behavior works as expected.....except for the driver side door. I can leave the vehicle with the key, close the driver side door, nothing beeps. I can manually lock all the doors in the GX, leave the key fob inside, and close the driver side door.....my keys are now locked inside the car. I'm guessing there's a proximity sensor somewhere around the driver side that detects the key fob? If so, does anyone know where it is?
Other info: Yes the running boards light up when I stand next to the driver side door. Yes, I can unlock and lock the car using the driver side door handle. Yes, I can start the car just fine without having to tap the start button.
#214
Both of my key fobs have new batteries. They both intermittently fail to unlock doors. I've read a few threads on possible problem keyless door module?
This problem just started.
Any information would be greatly appreciated.
Thanks
Thanks
#215
Only got one Fob when we purchased our vehicle. Torn between getting a $45 ebay version with a key or an OEM + key at close to 3x the cost. It will be just a backup since I only need one Fob. Are the ebay ones reliable?
