Key Fob - Problems & Questions
#106
Super Moderator
Lexus dealer told me they were cut on a machine that was $8-10k.... they claimed that was only reason they charged $20 to cut the blank I bought off eBay.
This is physical key that dealer successfully made a copy:
https://www.ebay.com/itm/351562110426
#107
I Bought my spare FOB and hard key from Sewell Lexus when they had their online parts site. I had to give them my VIN to have the hard key cut and paid my local Lexus dealer the flat rate $50 to program the FOB.
#108
But in the end, it is a much cheaper option for a "hide-a-key".
Note: it will not allow you to start your car. It will only get you in. You'll still need the key fob, ideally hidden in a RFID/Faraday pouch kept in your arm rest or glove box (or wherever).
#110
Unfortunately they can't do that. I don't know the process but I am sure someone here will chime in that used TS. Guessing you have to press a FOB button during the enrollment procedure.
#111
Makes sense and sorry to anyone if this is a silly question. What about the credit card key without buttons? For me, the thought of paying $250 (or more) for the credit card key + the cost of the hard key, cutting it and then programming it is kind of nuts....but I want it.
#112
Having just used TechStream to program my two new fobs, the process requires holding the established (programed and working) key fob next to start button (read: touching the push button). It will then beep and a timer will start that will give you about 30 seconds to hold the new key (un-programed) key fob touching the start button until you hear another beep. Give TechStream about 15 seconds to do its magic (you'll see a loading bar on your computer screen) and then it's done.
So given the process described above, I don't think a key fob can be done remotely.
Acrad (03-22-19)
#113
#114
Super Moderator
#115
it’s probably been discussed here before but I’m looking to extend the range of my factory key fob. I recently installed a new energizer battery and I still have to go to the window closest to my driveway to activate the remote start or lock/unlock the doors. There are times I’m 50 feet away and in direct view of my truck and I have to walk closer to activate. My wife’s Honda can be started from inside a mall while parked in the garage and it’s a fob not a phone app.
#116
bbqsoup (08-15-19)
#119
turns you into a resonance antenna.
maybe put a 1/4 dipole between the remote and the vehicle.
#120
Just in case someone thinks that i am crazy: https://www.apartmenttherapy.com/tec...care-rem-83663
