Thank you so much for the help. What is the best replacement light that is cost effective to buy? Name brand? Is it worth replacing both head lights with a newer version light for say the lexus 2021?
I am trying to determine if it is the headlight bad or something else. I don't have any dig. tools to prompt the light to work correctly. I am getting power to the light so I wonder if there is something in the light such as a module or motor for the auto leveling of just that light. With these lights is there away to replace just one part? I hate to replace a whole light that other then that function works fine. Even when driving if I need to speed up and rear goes down both lights adjust at the same time to through the lights higher and then they adjust back down. So my thoughts are that there is a separate part that controls just the auto leveling at start up. Any help anyone could offer would be awesome.
Also does anyone have the direct link to the guy that is selling the 2020 Lexus GX460 conversion lights for the older models.
There is just the single leveling motor in each headlight. Earlier 10-13 models with AFS HIDS had two as they have both horizontal and vertical control.
It sounds like it is at least partially working. Lexus would only sell this as a complete assembly. I'm trying to remember if I have seen someone take a '14-'19 assembly apart for repair.
I would think that if it was one part that failed it would be part # 1 in picture # 1. As it looks like that would be the only part that would not adjust on start up? I don't know if it is that simple. I have found a part that I think it would be on ebay. That is if it can be taken apart to repair? Thoughts?
Lexus Toyota 85663-30010 GX gx460 Right RH Headlight Adaptive Leveling Motor OEM
Do you happen to know if this is a common failure for this parts with the light not adjusting on start up? I searched for someone that might have done this before on the site and didn't see any information.
I frankly can't remember a report here on GX 460 on '14-'19 LED but if someone else remembers a post please let us know. There is a report on one of the Facebook GX sites of a 10-13 AFS model that rests in incorrect spot but works correctly while in operation. That person is still investigating issue but that is the only other report (different headlight system) I can offhand recall.
With no problem lights on drivers display and by all accounts everything working normal other then at start up it is hard to dig. the problem for sure. Just wish I knew what would cause the head light to not work right at start up, work normal for everything else it does and does not display a problem light? I thank you for all for help and I hope someone will see this post and possiabley help shine some light on what might be causing the problem.
Do you by chance have a link to that post on facebook? I have tried to find it but with no luck.
Can the headlight leveling motor right side/passenger be changed without having to pull the whole head light out? If so how do you ensure it will line out properly when reinstalling the new one? Finally got the part in and was curious.
