Interior Scratches / Scuffs / Marks / Blemishes
Old 03-04-20, 08:09 AM
  #46
NewGS22
NewGS22's Avatar
I've been looking at multiple Certified GX's (just waiting on the right one) and almost all used ones I've see have scratches on that silver finis
Old 03-04-20, 11:19 AM
  #47
hadokenuh
hadokenuh's Avatar
Carbon fiber wraps?
Old 03-04-20, 12:51 PM
  #48
tecman
tecman's Avatar
How did your touchup turn out Acrad?
https://www.clublexus.com/forums/gx-...olor-help.html
Acrad (03-04-20)
Old 03-04-20, 02:08 PM
  #49
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
I guess I never got around to it... I think the paint I purchased at time is still in garage. Weekend search... might be a spring project.
Old 09-13-20, 05:26 PM
  #50
ObsidianBl
ObsidianBl's Avatar
I ended up scratching my radio trim today. Has anyone found any touch up paint that matches?
Does the atomic silver exterior paint look similar enough to our interior trim?
Old 09-14-20, 01:51 PM
  #51
nuclearn8
nuclearn8's Avatar
this is a common problem with pretty much every Toyota out there.. Tacoma, 4Runner, Tundra... all the interior plastics scratch really easily, I've never seen a durable solution other than wrapping it or buying new pieces and applying a clear protective static vinyl piece to the pieces.
Old 09-14-20, 03:41 PM
  #52
ObsidianBl
ObsidianBl's Avatar
Looks like a wrap is in my future. I don't want to go all wood on the trim. It'll probably look tacky. The 2020's seem to have black gloss which is nice before anyone touches it...
Old 09-14-20, 03:46 PM
  #53
Acrad
Super Moderator
Acrad's Avatar
I still never got around to that touchup paint test. I'm thinking it will still stand out. My 2nd and 3rd row are down most of the time carrying cargo back and forth to my cabin so haven't notice the mark on the door for a while.
Old 09-05-21, 10:29 AM
  #54
casey008
casey008's Avatar
Lightbulb Interior Scratches
Is there a good cream recommended to help cover scratches from suitcases in the cargo area?
Old 09-05-21, 12:54 PM
  #55
Acrad
Super Moderator
Acrad's Avatar
I have heard some carefully use heat guns against the plastic but tread lightly if you go down that path. Not sure on technique
The following 2 users liked this post by Acrad:
casey008 (09-05-21), IanB2 (09-06-21)
Old 09-06-21, 09:18 AM
  #56
CFAI
CFAI's Avatar
Hopefully they will improve the quality of the plastics used in the cargo area in the next gen - current gen gets marked up after almost anything touches it.
Old 01-22-22, 04:37 PM
  #57
jlficken
jlficken's Avatar
Default What can be used to hopefully remove a scuff on the black interior plastic?
I was moving stuff for my parents and hit the wheel well plastics inside my GX and left a couple of scuffs. Is there anything that can help “repair” them?
Scratches happen but I was hoping to make it more than 2 months
Old 01-22-22, 04:48 PM
  #58
ASE
ASE's Avatar
Received 1,027 Likes on 685 Posts
If there are physical scratches ... nothing can be done ... use Meguiars #40 to minimize the visual.
Old 01-22-22, 04:49 PM
  #59
ASE
ASE's Avatar
... the reason I always have a King Size blanket in the Cargo area ... from Target that has some cushion.
Old 01-22-22, 04:53 PM
  #60
jlficken
jlficken's Avatar
Yeah I took everything out to make room to haul stuff and took the blanket I normally have out
Is this the stuff you recommend I try?
A gallon may be a bit much though
Quick Reply: Interior Scratches / Scuffs / Marks / Blemishes
