Interior Scratches / Scuffs / Marks / Blemishes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Dear Friends!
I am 200% sure that VSC issue will be fixed very soon. What I have noticed that plastic on doors is very soft and prone to catching scratches even of light touch. Does anyone know how to fix/disguise these scratches
Thanks in advance!
Thanks in advance!
Let's start by considering what Lexus advises. Here's the section of the online owner's manual concerning interior cleaning:
https://secure.drivers.lexus.com/lex...html&locale=en
Water! More specifically, a cloth dampened with lukewarm water. Try that first to be sure the interior surfaces are clean, then we'll need to consider something a little stronger than water ... maybe Windex.
Regards,
SaniDel
Regards,
SaniDel
I previously owned a 07 GX470 and all the plastic interior parts scratched much easier than any other vehicle I have owned. I guess its the trade off for the feel of the plastic not feeling hard and cheap like on many vehicles.
greetings from the RX forum ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
We just had a discussion on this. I am assuming you are talking about the bottom of the door panels. People recommend using the Mr. Clean Magic Eraser. However, it is a light abrasive so be very careful using it. Just a light swipe should do.
Dysfunctional Veteran
There are plenty of Vinyl/leather/plastic (not nessecarily all in one) products that are readily available, even at retail locations. You had the right intentions SaniDel, just the wrong product.
I am going to be blunt. DO NOT use windex for anything except un-tinted glass, and occasionaly chrome (depends on what kind of chrome). Windex has ammonia in it, which will ruin the finish on most automotive plastics. Sorry for contradicting you Sani, but i just needed to say something. It could literally ruin the dash in 1 go.
May we assume you also recommend against the suggestion made by 'Resident' to rub graphite powder into the plastic? It seems the Mr. Clean Magic Eraser would be a better choice, but just a touch, right?
Regards,
SaniDel
Anyone notice the silver looking plastic on the dash and console scratches super easily too? And the issue is not dirt so it's not about cleaning it, it's that it indents very easily, you can see the scratch and even feel it if you run your finger over it. There's no cleaning that. I have a habit of throwing the keys in the cupholder and sometimes I miss. There are already scratches after 1.5 months of ownership - it's going to to be horrible after a year or 2!
Thanks for the warning about the plastic on the dash and console. We noticed one small scratch and we will try to limit it to one. We keep a microfiber cloth in the center console for when we "feel the need" to wipe the dust without causing another scratch.
Regards,
SaniDel
I don't know about the European cars such as Mercs, BMW's, and Audi's, but the material in the GX 460 seems to be of lower quality than the plastic in my old 1998 ES.
Also, where do you folks put the Smart Key when driving? I have a big headache right now as to how to put my keys in my pocket. I used to have a key pouch that I could put everything inside, but because the Smart Key was too bulky the zipper of the pouch had burst open! I was thinking to get a key case, but once again the Smart Key was too big so the key case wouldn't close. People have been telling me to put my Smart Key in the left pocket, and my other keys - in a key case - in the right pocket. It's inconvenient but it seems that's the inevitable direction I have to be heading. Sorry I think I'm off topic.
Thanks for the correction and the advice, OCDetailer. Windex is certainly not the right product to use on anything made of plastic and now we know why.
Regards,
SaniDel
Regards,
SaniDel
My point to all that was simply that without even realizing it, certain chemicals can literally ruin certain materials, sometimes in seconds. I am sure that on plastics, you can probably get away with it for a few times, but I would not imagine Ammonia is healthy for anything except glass and porcelin.
The graphite solution...I am not sure. It would depend on what color the panel is, etc etc. It would only be a temporary solution. I know for cracked panels, I use a color matched filler. You purchase the filler (kind of like bondo) and have a paint shop add paint to it to match the color of the panel you are fixing. However, this only works on non textured panels, or very small cracks, or cracks that are in an inconspicuous place, and will not be easily seen.
Keys? You don't need keys for the 2010 GX. Keep the "electronic key" (a.k.a. the fob) on your person, e.g., in your pocket and your house keys somewhere safe where they can't scratch ... you can unlock, start, stop and lock the GX by touch.
Regards,
SaniDel
Regards,
SaniDel
Windex Original contains Ammonia, other types of Windex such as CrystalRain and MultiSurface Grease Cutter do not. These should be safe to use. Ah, also do not use any products with vinegar like Windex MultiSurface Vinegar (sic), they can also easily discolor leather, carpeting, etc.
regarding the plastic metallic trim. This seems to be the same plastic they use in all their cars (except for the LX which uses a real aluminum finish). I dont see an easy way of fixing those scratches. Just try not to throw keys at it ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
as for the door panels, the problem isnt exactly a lower quality plastic. The problem is using plastic. A great touch on my C class is that they wrap the bottom part of the door with a fabric so that if your shoes touch it on the way out, it will leave a mark that will disapear with water. Hard plastic just scratches too easily and its a bad choice of material
Sorry ... I jumped to a conclusion based on your screen name! ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
My wife and I both broke the habit of keeping our car keys with the rest of the keys on our key rings. Our GX was delivered with a black and a grey leather bag for the "electronic keys" that would be indistinguishable otherwise. The black one goes in my pocket and the grey one goes in her purse ... the rest of our keys go somewhere else, but they remain out of sight ... and out of harm's way.
Obviously, "key management" is a personal matter, but I've only found one flaw with our approach ... the car wash. Leaving the GX running with the electronic key in your pocket causes two problems:
1. The GX beeps, which is embarrassing at the car wash, and
2. The GX won't start at the end of the car wash line!
My solution is to hang the electronic key on the windshield wiper stalk using the short loop on the leather bag. Step out of the truck and it doesn't complain, plus it will restart at the end of the car wash line. The only problem the crew on the car wash line has with the GX is the side swing door AND the pop up rear window!
Regards,
SaniDel
Regards,
SaniDel
