Reverse Lights Not Working
Hi All, yesterday in a parking lot I was informed my reverse lights are not working on my 2011. I reviewed the fuses in the manual but do not see one specifically for those lights. Since none of them are working but the brake lights and tail lights are I suspect something else is going on. Any suggestions or ideas on where to focus? Thanks much!
Maybe both bulbs are out check that first.
also the electrical and mechanical parts of the system for reverse are separate. meaning theres a switch that tells the vehicle its in reverse, and this goes to controller that does some thinking and controls lights, camera, etc. example you can get reverse camera without reverse lights, or the other way around, or even reverse gear since separate.
its not common for the fuse to burn out, usually a single bulb or the switch.
wpb_mike (01-06-22)
Thank you John. Do you happen to know the proper name of the switch that I can search for? I've ordered some replacement bulbs and will plan to tear into it this weekend. Thanks again!
https://www.clublexus.com/forums/mem...32-john00.html
