Gx570
5th Gear
Gx570
First post here so don't really want to get into the whole introduction thing but I like to say I am one to be "a trend setter" not much of a "follower". As far as I know no one has done a 5.7 swap into the GX platform so I am gonna be doing it soon as in maybe next week if my work load allows.
I have also built the first 4.7 iforce v8 2nd gen Tacoma 4x4
I have a 2004 is300 with 800hp
I am looking forward to this experiment.
Super Moderator
Aren't engines on the outside at least dimensionally about the same?
What do you perceive to be the greatest challenges? Are you using the ECU out of the Tundra as well?
Subscribed.
The ECU and BCM are my main curiosities.
Super Moderator
Any updates to your engine swap?
GXLUX (02-14-22)
not 100% sure but i think the entire UR family of v8's use the same block. from what i have read the bores are all the same just longer strokes. can anyone confirm
dwh13 (09-12-22)
Send him a private message and maybe it’ll trigger an email notification.
MrTorgue (06-15-23)
5th Gear
So this is where I am with this, I started on this project about a week ago and so far I got this information to share.
The 3ur and the 1ur blocks are definitely not the same the 3ur is a wider "v" than the 1ur and is taller
The heads on the other hand are the same... not this is the same but just gotta change this kinda the same it is actually the same heads.. my 1ur has 3ur heads they are literally stamped 3ur- LH and 3ur-RH
The upper and lower oil pans are interchangeable. I am using the 1ur oil oil pans on the 3ur.
The a760 bolts to the 3ur BUT need to redrill to fit the starter and use the 1ur flex plate
5th Gear
2010 GX570 build
I am happy to say that I have successfully completed the 3ur-fe engine swap into the GX
if this tread picks up and I get people that are interested I will do a complete build break down
The following 2 users liked this post by 671gx570:
MrTorgue (06-11-23),
TXgearhead (06-15-23)
I'm curious how you handled the BCM and infotainment. Did you use the factory GX's ECU and BCM? Any modifications to the factory wiring harness?
5th Gear
The factory harness from the GX was used along with the factory ECU .
MrTorgue (06-11-23)
MrTorgue (06-15-23)
