Front facing carseat question
10th Gear
**Edit - 2nd row are captains chairs**
Hi Guys
Wondering if anyone went through this and found a solution. I realize this probably isn't the typical question since it's not about nodding or aftermarket stuff but hopefully someone knows.
I recently changed my 3.5 year old daughter's car seat from a rear facing to a front facing. It installs fine and everything, but the height of the carseat "butt position" doesn't work well with the back of the front seat. Because the GX front seats have sort of a dramatic curve toward the top of the seatback, her feet are always touching the seatback. There is so much room below that area though but the height of the car seat means her feet dont dangle that low.
I'm not sure if I'm describing this well enough but hopefully someone understands.
Anyway, I'm wondering if it's more of a carseat issue or if it just is what it is. Shes using the Chicco MyFit Harness + Booster Carseat which seems to be universally loved and I dont see anyone complaining about the seat height.
Has anyone run into this issue and found a solution or a front facing car seat that was "low enough" to have your child's feet comfortably hang behind the front seat?
Hi Guys
Can you provide pictures?
10th Gear
The photo probably doesnt show the problem very well. But basically she is so high up from the seat and her legs dont exactly hang off of it, they just sort of go straight out. And because the angle of the front seat back arches back up high, her feet are always touching it, even if I move up pretty substantially (and I'm 6'3" so I don't want to compromise on my space too much).
So it seems I need to find a new car seat but they don't really do a great job of telling you how high up the seating position starts relative to the height of the seat overall.
That's definitely a car seat problem. If there's nothing else you can try with seat adjustments, car seat adjustments, etc. and if you don't want to buy a new car seat, though, you can get one of these. It might not make sense to buy a new car seat anyway. Kids outgrow those things so quickly.
Unless you drive a minivan, I think even big SUVs like a Tahoe and Suburban will look like this for you. You're tall, she seems tall for her age, the car seat has a thick seatback and thick seat. I recall my kids' car seats having thinner profiles, but I don't recall which brand and model.
You could try to use a pool noodle cut to length to make the carseat more upright. I recall we did that with our rear facing seats and it was kosher. Because my wife is really finicky about the car seat safety and I remember she was fine with it. So I think you could put the pool noodle or stack a couple of them under the rear of the carseat to provide a lift if that makes sense.
Not sure if that was helpful
Seanzky (01-13-22)
10th Gear
Link:
MrTorgue (01-13-22)
s4play
11-26-10 07:02 PM
jditom
GX - 1st Gen (2003-2009)
10-25-07 11:13 PM
