2022 GX Side Mirror Reverse Malfunction
Hello,
When we purchased our 2022 Black Line and went to leave the dealership, the drivers side mirror auto adjusted when shifting in reverse since the switch was in the L position. But what confused me was it adjusted up instead of down and even clicked because it went too far. I figured it might be a fluke and decided to test it later. So this weekend I did just that and it’s still angling up not only with the left mirror but also the right.
The manual says:
Linked mirror function when reversing
When the mirror select switch is in the L or R position, the outside rear view mirrors will automatically angle downwards when the vehicle is reversing in order to give a better view of the ground.
Here is a video of me shifting into reverse and what the mirror is doing.
Has anyone seen this before? Any ideas on how to fix it? I don’t understand how this even happens, especially with BOTH mirrors.
The manual says:
Haha. This happened to me, too, when I first drove mine. Scared the crap out of me.
If you're going to use the mirror tilting down in reverse, set them both to the way you want when in reverse. Put it in 'D' and they should return to how you had it. Put it in 'R' again to make sure they tilt down to the way you want them for when in reverse. Then save it along with your seating position.
The following 4 users liked this post by Seanzky:
Yeah it looks like they failed to calibrate them at the factory...oops.
Seanzky (02-02-22)
You can watch the 2022 GX 460 Tutorial on UTube and the lady giving the tutorial does exactly this when talking about adjusting the mirrors for reverse. Before I got my GX I did thus on my RX and it worked like charm.
While in reverse (R), just hold the brakes, push on either of the L or R of the mirror adjustment rocker switch, adjust mirror, then do the same for the opposite mirror. Once both mirrors are tilted down and to your liking, leave the rocker switch on either L or R, go to drive (D) and make sure the mirrors return to how you like them while you're driving, then go back into reverse (R) one last time to see if the mirrors change to how you like them while you're reversing.
Clarification on the Reversing Mirror positioning. This thread correctly describes how you
adjust the mirror angles while in reverse. Please note that the this reversing position is Not
saved into the 1/2/3 memory system, all drivers will get this positions when reversing if the
mirror selector is set to R or L. Centering the mirror selector disables the reversing position.
DSMinATL (02-02-22)
Yes! I can't imagine how many complaints they've gotten for what owners probably thought was a broken sideview mirror and they still haven't calibrated it from factory! Haha. I was just so glad and relieved that it was just a thing that needed adjusting.
