Need new Struts and Shocks
For those that want the floaty ride the KDSS bypasses essentially accomplish that. There are a couple out on the market now for 460 and 4R by Dr KDSS or Blackgatecustoms.
There also appears to be single ground wire near the left tail light that can be toggled on/off to obtain same behavior
https://www.clublexus.com/forums/gx-...l#post11088806
FRONT PAIR OF QUICK COMPLETE STRUT & SPRING ASSEMBLIES - LEXUS GX460 & GX470
00 REVIEWS / 0 QUESTIONS / 1 ANSWERS
PART #: 2-55S11565-001
CONDITION: NEW
AVAILABILITY:
Out of Stock
Please select your vehicle
from the above to check compatibility
$256.49
I def would want to keep the KDSS operable. I’ve decided to buy new stock rear shocks and use a strut coil combo for the front from suncore $254 plus shipping for the pair when they are back in stock.FRONT PAIR OF QUICK COMPLETE STRUT & SPRING ASSEMBLIES - LEXUS GX460 & GX47000 REVIEWS / 0 QUESTIONS / 1 ANSWERS PART #: 2-55S11565-001 CONDITION: NEW AVAILABILITY:Out of StockPlease select your vehiclefrom the above to check compatibility$256.49
With all due respect ... $254 for a pair of strut assemblies ? Quality springs are in that same price range ... so these are clearly bargain basement. I would not install these on my lawn mower let alone a Lexus. $127 per assembly ? ... no question, those shocks are garbage.
ballistice (02-12-22)
All good ... my take ... given suspension and tires determine vehicle dynamics from a handling and performance standpoint, let alone the safety aspect (emergency maneuver) ... this is not the place to cut corners.
IanG (02-11-22)
You should check out your friends setup or maybe test drive his truck/suv before purchasing and installing the suncore stuff. I wouldn't put those on my GX. You probably dont need new coils anyway and a set of Bilstein 4600s are abt $350 so not saving much.
ASE (02-14-22)
The Ikon (02-24-22)
I am leaning towards bilstein now but wondering if i should go with 4600 or 5100? Bilstein doesn't have a part# for lexus GX but they do for 4runners but the 4runner is abt 400lbs lighter then the GX so not sure if 4600s would be too soft ?
Anyone installed either of these on thier 2nd gen GX ?
5100's on the GX470 required the first lowest lift setting... otherwise the stock springs were not adequately compressed as an assembly ... so resulted in a 1.25" front lift. Not sure on the GX460 since I lifted anyway using the stock springs.
detrouge (03-16-23)
I used to have a 2012 Tacoma with Bilstein 4600 as OEM, I upgraded it to Bilstein 5100. There is a big diff. between the 2. The 5100 is LARGER in diameter. There is another version for Bilstein, 6112. This one is also larger than the 5100 and maybe better for the heavy GX.
Between the 4600s and 5100s when you say there is a big difference which one provided a better smoother ride for daily driver?
I am thinking the 4600s will be a lil stiff/firm compared to oem lexus and i may not like 5100 if they are stiffer.
I use my GX mostly pavement
The 6112's do have a larger shock body ... so are more of an off-road shock given the larger damping volume.
