2022-2023 GX Infotainment Questions, Problems, Concerns
FOGeologist (01-12-24)
#107
Radon still on while ignition off
I have a 2023 gx460 premium. So I am a bit confused as to why when the engine is turned off the radio shuts off and the steering wheel retracts back if, I want to continue to listen to the radio in axillary mode I have to hit the start button again at which point the steering wheel comes out.
Is there a way to bypass all of that? the radio and or other electronics should remain on until you open the door, not when you turn off the engine. When you sit at the train crossing and just want to listen to the radio without burning precious fuel it is annoying to keep turning the ignition off and on.
#108
the “hack” I’ve discovered is to turn off you GX while it is still in gear (e.g. “D”) or in Neutral. The radio will stay on (in accessory mode). It will remain in accessory mode for several minutes before going to sleep, if I recall. Kind off a work around, but it gets the job done.
PNWRacer
GX - 2nd Gen (2010-2023)
16
11-14-19 12:38 PM
Huiezzy
19
09-23-17 12:28 PM
jimkerri
04-19-10 03:30 PM
