Leveling kit for 2022 GX460
If your vehicle has the rear auto-leveling option you will also have AVS (adaptive shocks) and KDSS. Lexus engineered these components to work perfectly together, especially when towing. Unless you want to lift the vehicle for ground clearance (bigger tires) I recommend, don't change anything. Even a simple spacer will reduce the travel/stroke of the susp. (very minimal). The GX is amazing off-road, the only issue is ground clearance. The clearance is the limiting factor for off-roading. The problem with lifting the GX and maintaining the ride/towing quality. To do this the right way you would probably spend approx $10K. Many components have to be modded to properly lift the vehicle. Do yourself a favor and leave the GX stock unless you plan on moderate off-roading.
Cmdwolf (12-23-23)
Thank you both so much for your replies. I will indeed be putting larger tires on as well as leveling the front at minimum. I did a 1/2 inch top plate spacer on my Tacoma Pro and loved the 1 inch lift that I gained from that. If the top plate doesn’t net the results I’m looking for, I’ll likely go Dobinsons. Though I do realize the Lexus systems are designed to work in unison, I am not looking to lift the rear. I’d still like to know if I were to level the front, will the rear air bags try to level the rear on their own to “catch up” to the leveled front end? Thanks again
aredub (03-22-22)
To lift the rear by shimming the limit switch is easy. Lowering the height is not that easy. You will need to move the arm/lever. If you are going to do this, only move the arm a tiny bit at a time and mark the original locations (so you can revert back if needed). If your goal is to level the vehicle and you were happy with a spacer on your Taco, the GX will work the same way. If you want bigger tires (depending on the size) you may need to invest. To avoid a lot of other mods I recommend not exceeding 33" tires. You would avoid a body mount chop and re-gearing. If you spend most of the time on-road don't go too big.
Koz (03-23-22)
Do not go the spacer route ... not a good solution. My approach was to install Toytec Ultimate Coilovers ... Bilstein 5100's with a threaded lower spring perch collar .... so the ride height can be dialed-in to an exact height on either side of the vehicle. The added bonus is that the dreaded "driver's side lean" can be easily addressed in the future. For me ... I wanted to preserve some front end rake ... but agree, the stock stance is way too "nose down" .... so I lifted the front end just under 1.5-inches given 2-inches starts to cross the line to where drive shaft angles becomes a consideration.
did you lose any of the good ride compared to stock?
How about steering and drift on highway at higher speeds? Thanks. Just joined the gx club
skeener (02-05-24)
