Leveling kit for 2022 GX460
#31
5100 install
Do not go the spacer route ... not a good solution. My approach was to install Toytec Ultimate Coilovers ... Bilstein 5100's with a threaded lower spring perch collar .... so the ride height can be dialed-in to an exact height on either side of the vehicle. The added bonus is that the dreaded "driver's side lean" can be easily addressed in the future. For me ... I wanted to preserve some front end rake ... but agree, the stock stance is way too "nose down" .... so I lifted the front end just under 1.5-inches given 2-inches starts to cross the line to where drive shaft angles becomes a consideration.
#32
hey, do you have another thread where you detailed the install? I’m looking to do exactly what you’ve mentioned. I’d like the level of front end a little bit and also have some side to side control. I’m curious did you use the stock springs and what original hardware was retained compared to what hardware from the 5100 did you have to use?
Again ... for me ... the ability to dial-in height ... and side-to-side ... makes this a great solution for all reasons. Have the same setup on an FJ Cruiser (with 600-lb. Springs) that had a full inch of body lean on the driver's side ... but no more.
If you are a "Toyota Person" ... these fit on so many of the later Toyota body-on-frame vehicles ... since the suspension is essentially the same. So my point ... save the original shock assemblies... so you can move the ToyTec Ultimate Coilover (hardware) to another vehicle in the future.
