2022' Front turn signals cracked/broken
Glad I could help! I think my OCD might take over on this one and I'll just order another new one. Thankfully it wasn't the $260 part number, I knew that this was just an update on a part number but nothing changed. I was hoping I could also find some LED full housing replacements, I just have some bulbs with built in resistors that work well, but the GX really keeps riding the old incandescent train.
and thank you for verifying old part number is teh same part as with new part number
lostape45 (07-18-22)
Front turn signals
My 2018 has a cracked lens cover on the passenger side front. It looks like Rock Autoo has the lens cover only for about $50.00. Would I need to remove the whole assembly to just replace the lens cover? Thank you.
I removed the fog light housing (3 x 10mm bolts) first to get better access to the tabs on the lens housing. The tabs are tricky, but once you know where to press the on the 3 tabs to release it, the housing will come out fairly easy. There is at least 1 10mm bolt for the lens housing (don't remember now) and I also removed some bolts to the lower tray (in front of the wheels) to move to the side for better access and visibility. The wire to the bulb holder is clipped to the lamp housing which needs prying off before removing the lamp.
Suspension
05-21-22 05:05 PM
Hoovey689
05-21-12 12:07 PM
