Method or TRD Pro rims and tires
Hey folks. The Bridgestones on my 2022 are starting to wear with only 9k miles on them. If I am going to get new tires soon, I might as well get some new lighter and smaller rims to improve ride quality.
What are your thoughts between the TRD pro wheels vs this from Method racing? They are both about the same weight. I would have gotten the 17x8 Method for even more weight savings, but its not in stock.
https://www.methodracewheels.com/col...31755721769021
Also, for tires, I want lighter truck tires since I'm a "mall crawler" so I'm thinking some Michelin Premier LTX or Primacy LTX. What tire size is a safe bet to not have any rubbing issues?
Thanks.
Thanks.
I think those Method wheels look great, although pretty common. Those aren't the exact ones you're buying, though, right? You mentioned 17x8 aren't in stock but those are and they're not the 6x bolt pattern. The TRD Pro wheels look good and are also about as common. I'd go with the cheaper one if I had to choose between the two.
Method ... all Toyota wheels are 7.0" or 7.5" width with way too positive (inboard) offset. Go with 8.0" width ... with more negative (outboard) offset to eliminate the Toyota "Soccer Mom Stance" ... will result in improved cornering stability.
2chains (08-31-22)
Dunno what color your GX is, but I had those wheels with 265/70 Falkens, in 17x8.5+0. I actually really liked them and they're a great value wheel, but I also didn't want my car to be a black blob so I sold them for bronze wheels. The color is misleading on the site and way brighter than they actually are. They are black.
![Method or TRD Pro rims and tires-wpiinph.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485585d1683149119t-method-or-trd-pro-rims-and-tires-wpiinph.jpg)
![Method or TRD Pro rims and tires-r0e4sth.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485586d1683149119t-method-or-trd-pro-rims-and-tires-r0e4sth.jpg)
![Method or TRD Pro rims and tires-h2lal4t.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485587d1683149119t-method-or-trd-pro-rims-and-tires-h2lal4t.jpg)
![Method or TRD Pro rims and tires-ljlvwrg.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485588d1683149119t-method-or-trd-pro-rims-and-tires-ljlvwrg.jpg)
![](https://i.imgur.com/WPiInpH.jpg)
![](https://i.imgur.com/r0e4StH.jpg)
![](https://i.imgur.com/h2lAL4t.jpg)
![](https://i.imgur.com/LJlVWrG.jpg)
They are hubcentric. Just remember to buy aftermarket conical lugs - these accommodate the ET (extended thread) ones. If no mods, then sticking to stock height is probably best, which is 265/65R17. It doesn't take much to fit a 265/70R17 - all you need to do is push some plastics out of the way, but it varies tire to tire. I don't think the Michelin LTXs will give you any problems.
ASE (08-30-22)
id go with trds if those are the 2 choices. better to have the tires 'in' and narrower for most if not all on road and many if not most off road conditions.
This is the same truck a few months later with -10 wheels, but same tire. They stick out slightly more. I'm not sure if the +4 TRD Pro wheels will poke really that much less; they're only 4mm inboard.
![Method or TRD Pro rims and tires-arorw1o.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485575d1683149119t-method-or-trd-pro-rims-and-tires-arorw1o.jpg)
My brother and I have a wheel problem so we've been able to directly compare.
![Method or TRD Pro rims and tires-n6tcihr.jpg](https://www.clublexus.com/forums/attachments/gx-2nd-gen-2010-2023/485576d1683149119t-method-or-trd-pro-rims-and-tires-n6tcihr.jpg)
@situman you could also take a look at these few posts and see if you like what they've done. Might save you a few bucks to just to go a slightly larger tire on the stock wheels (that you know won't stick out).
https://www.clublexus.com/forums/gx-...l#post11296139
