GX Starts, Shuts Off, Doesn't Start Again
This a northern rig? If so, it might be rusting heavily due to salt/snow exposure. You'll have to check the manual to find all of the factory ground points and you might want to examine those to make sure that they are not falling apart. If that is the case, get them cleaned up and then spray an anti-corrosion spray on them.
I have same problem Lexus Gx460 2011
I have same problem with my car Gx460 2011
I have on Cluster 3 light check engine, Trackk off and 4x4 Low im not sure why
I replace the ecu fuse, is start but engine is died in 3 second, i read now 4 code P0058, P0351, P0357, P060A what i need to do ?? HELPP PLEASE
I put my money on either of the following, first clear all codes and monitor when it happens again
then
1) Check the coils
2) Check the spark plugs
3) Check the fuel pump
ecassaro19
05-15-18 01:22 PM
