Vehicle firearm holster
Hi all.. looking for ideas ( location, product recommendation etc ) for installing a holster in the vehicle with easy/safe access.
Wondering if any one has such an install done in theirs ? Thanks!
If you have the center console safe, I've seen installs inside there by mounting a holster to the side of the metal safe. It's only a single bolt in the bottom to remove the safe.
For storage or for access? For storage that’s an easy one, grab a console safe. For immediate access you could mount a small molle panel and affix a holster to it down under the dash or to the right of your foot/leg on the side of the console. Personally I just keep it on my person at all times.
Need something for quick access. I was practicing my draw ( wear it on the strong side with in a IWB holster ) from a seated position, and it was .. well.. not what I'd want to be struggling with *if* I ever need it.. And, I'm not a fan of appendix carry. Plus, my muscle memory is trained with 4'o clock IWB holsters since I started carrying.
I occasionally drive from Dallas to Denver, and driving with it on person gets a bit uncomfortable. I never leave the firearm in my vehicle ( even when I stop for gas or restroom breaks ) so don't really need a safe.
I like the idea of mounting the holster ( perhaps even a sticky holster that's not firearm specific so it can accommodate my EDC rotations between a Glock 19 to a Sig p365 and alike.. ) but the idea of drilling in to the side of the console is a bit concerning ( should it be ? )
I store mine inside my waist band.
For me, it doesn't matter if it's strong side or appendix. I compete using both positions so I'm very comfortable and quick either way --much quicker appendix when driving. I've driven to Colorado Springs (I think this was my longest drive carrying?) and it didn't bother me one bit, but of course that varies with body types, etc. If (big if) at any point I feel uncomfortable, I wedge my holster inside the center console where it's quickly accessible if I need to get to it. I think I might have done that once during a long drive and I can't remember why... it wasn't discomfort.
More importantly for you, since you go to CO a lot, is to remember to switch out to 10-round magazines.
MrTorgue (09-27-22)
Easy to install and you can affix a holster to it.
MrTorgue (09-28-22)
In that case I'd recommend this molle setup, https://www.victory4x4.com/product/VGXCC.html
I's think the CONS of having a vehicle mounted holster outweigh any PROS
- going to take a lot of reps to become even mildly proficient, since it's something that must be trained in through deliberate a training activity and repeated, meaningful practice
- retention in a crash
- an emergency bailout, forgetting the blaster
- a normal exit, with thought process occupied, and forgetting the blaster
I'd want the pistol on my body and work out any kinks with dedicated training / practice.
I do intend to practice my draw to develop memory muscle, for that *in case* scenario.
I've been training for a few years ( including some professional classes over the course .. ) that has, among other benefits, disciplined me enough to not forget the firearm in the vehicle ( even briefly )
Much as I'd prefer to always have it on my person during the long drives ( and I usually do, esp the sub compacts ), it does get somewhat cumbersome at times.
Is it 4oclock IWB? OWB? Are you saying you completely remove it or just remove the pistol for comfort and leave holster on?
Slide to 3 or 2:30 with seatbelt repositioned wont help? I agree with thoughts on needing quick access but also wanting it on body since things going sideways is chaos, better on-body.
Something i saw was a reposition and loosen belt for travel, then a shift and tighten when getting out to walk around.
I'm not yet experienced with travel carry but OWB sounds more conducive in those instances.
I'm liking the molle panel options available, and will probably go that route!
Desert Does It Mmp, with a serpa holster on a quick release mount is the answer. I can remove my holster and take it with me in seconds, and it’s locked in place in a perfect position while driving.
Seanzky (10-05-22)
Wow! That's actually a much better solution than the kick panel molle one. I can already tell it's a much more natural reach and draw.
You might want to check this out. It's not on the console, but under the steering wheel, easy to reach & doesn't require drilling.
https://www.gumcreekcustoms.com
The following 2 users liked this post by Latte1:
Motomotion (07-06-24),
MrTorgue (06-26-24)
MrTorgue (06-26-24)
Bill P.
GX - 1st Gen (2003-2009)
08-29-04 03:55 PM
