Traction/Stability control problem
7th Gear
Was driving in sand in 4H and switched my traction and stability control off, by 3 second push, both lights illuminated. I later drove some in 4L and both lights remained on. After switching back to 4H the stability control light went out, while traction remained on. I then tried to turn everything back on, but switch does not respond. I then went back into 4L and both lights came back on. I turned engine off and on with no correction. I then disconnected battery for ten minutes and again no correction. Any ideas anyone please ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Super Moderator
Super Moderator
The wheels on the display should come back after 300 feet or so driving straight over 25MPH
Super Moderator
Did you just pull codes with a standard OBD reader?
ABS level codes require Techsteam, multi-hundred dollar readers or something like OBD Link/Fusion to pull codes
Super Moderator
That usually doesn't undo itself just driving around though. No harm in trying to reset and set it. Process is documented here or resources in crawl control retrofit thread. Disconnecting battery always resets that wheel direction indicator but doesn't reset ZPC either.
https://lexusgxor.com/_media/general...caibration.pdf
You can only do paper clip reset in 10-19 models and note orientation of OBD port is 180 degrees from picture in PDF above
If that doesn't reset you will need to use one of the other tools I mentioned to pull codes. The need for a ZPC shows up as DTC C120A so if your reader isn't displaying that it isn't capable of extended code reading.
Is your vehicle lifted? Model year? How long have you had it?
Super Moderator
If that ZPC doesn't work then your probably gonna have to spring for a different test tool
Acrad (11-17-22)
