View Poll Results: How many storage boxes do you have in your GX
1 Small box for emergency items only
50.00%
Multiple boxes of varying sizes
37.50%
None, I use the roof rack for that kinda stuff
12.50%
Voters: 8. You may not vote on this poll
Rear Cargo Storage Boxes
Just curious if any of you have a dedicated storage box that you keep in your GX behind the second or third row of seats all the time. If so what size do you have and what brand? I'm thinking about getting a couple of varying sizes to keep in my GX rear cargo area. One to keep at all times to store just basic emergency items (bigger 1st aid kit, jumper cables, etc) and then one for Offroad use (air compressor, saw, hatchet, drill, tow straps,etc)
Drawer solutions for GX460
Probably more than what you want but I'll put it out here... I don't have boxes but I do have storage drawers. I removed my 3rd row seat to have the storage drawers added. There are a couple of solutions, if you want drawers by - Goosegear, Dobsinsons, Air Down Gear Up, etc. Truckvault also has drawer solutions.
BTW - I recently saw this drawer solution by Rugged Bound Supply - looks like they are based in Houston, TX (I've not seen their product in person).
Rugged Bound Supply
Good luck.
Rugged Bound Supply
Good luck.
Last edited by SEELEXUS; 12-18-22 at 07:36 AM. Reason: Updating with Houston drawer solution
Rugged Bound Supply
Good luck.
Rugged Bound Supply
Good luck.
would not fit behind 3rd row, but i would got mechanics tool bag or something similar in that case.
the Plano are not overbuilt, but fit the "good enough" use case most of the time. They're cheap, and available.
Had another idea - how about something like what Stepp22gear offers? I have some of their items and it is all top quality.
Step 22 Gear
Step 22 Gear
These are in the rear, all the time, no matter what. If I need to put something else and it doesn't fit because my storage tote (or whatever you want to call it) is there, too bad. It goes on the roof, hitch cargo carrier, etc. This is in the GX, always, non-negotiable. I usually have a case of water bottles there, too.
GXNick (12-19-22)
Just got back from a elk hunt that me and my BIL enjoyed in my new GX. With second row seats folded down we took two 150 quart and two 35 quart ice chest. All our gear except our rifles traveled inside the ice chest. One processed elk will fit in a 150 quart ice chest. The gear that was inside rides on top of cooler. We had plenty of space and could see out the back hatch window. Antlers can ride on roof cross bars.
I’ve got a medium Plano Sportsman Trunk. Fits great between the two tie-downs, and is secured with a thin ratchet strap. It’s filled with first aid kit, water, recovery gear, gloves, collapsible shovel, sleeping bag etc..
The following 4 users liked this post by jcgx:
I like instacrate. I keep one in my trunk to throw small things/groceries/etc so they don’t roll around. I can easily fold it and get it out of the way if needed.
I believe this is specially useful in the GX given the little space behind the 3rd row. Having a regular box means you’d need to leave your box behind if you have to use the 3rd row and weren’t able to plan ahead.
Have a FrontRunner hard box for the important stuff, along with a soft Truck Crate from Amazon for the everyday stuff.
A lot of great options mentioned so far. So after researching a bit and looking at my local hardware stores, I decided on the Ridgid Pro Gear system. I like that they are modular, stackable, lockable, and even have a waterproof gasket. My every day kit will be the smaller power tool case as its big enough to fit "emergency" needs (More on this and will add pictures when I complete my kit). Also, it will fit behind the 3rd Row Seat when up without issue.
When going on Trails I will add the larger rolling case to accommodate a portable air compressor, tow straps, collapsable shovel, and any other potential needs. This is always an ever evolving process so this will be good to get me started. I Don't want to become a "gear junkie" but want practical needs met. This should fit the bill.
ColdIron (01-07-24)
storage
Rugged Bound Supply
Good luck.
Rugged Bound Supply
Good luck.
JimInTN (01-07-24)
