'14+ Diagnostics
Old 03-13-14, 06:18 AM
gzorn
gzorn's Avatar
Lightbulb '14+ Diagnostics
So in sitting with a service tech discovered how to access some of the diagnostics.
Access at your own risk.
First is a diagnostic screen.
Hold the SETUP button on the center console and flip the headlight switch between OFF and ON 3 times. You get this screen
Old 03-13-14, 06:23 AM
gzorn
gzorn's Avatar
Default Service Screen
The second screen is called "Service Menu". To access hold the INFO button on the center console and turn the headlight switch from OFF to ON 3 times. You will end up at the first pic. To fully exit the service menu you must turn the car off and back on then hit OK in the 2nd picture.
Attached Thumbnails '14+ Diagnostics-img_0802.jpg   '14+ Diagnostics-img_0803.jpg
Old 03-13-14, 08:07 AM
Eppieguy
Eppieguy's Avatar
Interesting find, wonder if it's the same on the 2010-2013 navs? I guess I'll find out.
Old 03-13-14, 08:21 AM
Lolrax
Lolrax's Avatar
Cool!!! Can you adjust settings or anything in there?
Old 03-13-14, 09:30 AM
gzorn
gzorn's Avatar
Not sure what is available for adjustment/settings. He just went into service menu for a quick check of product info and I discovered the 2nd by accident. Have not had a chance to play, maybe when the weather is warmer.
Old 03-15-14, 10:06 PM
MyGX460
MyGX460's Avatar
I got to the first screen , where is the info button? I can't find it .. Please show me ..
Old 03-16-14, 03:09 AM
gzorn
gzorn's Avatar
The INFO button is just above the SETUP button to the right of the screen.
Old 03-16-14, 08:28 AM
MyGX460
MyGX460's Avatar
I don't have nav ... The info button is not there ....
Old 03-19-14, 05:12 AM
gzorn
gzorn's Avatar
Can't help you there. My only suggestion is to try hold down any of the other buttons while flipping the headlight switch to see what pops up.
Old 01-30-21, 07:01 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,651 Likes on 2,390 Posts
This is listed as starting in 2021 but something for 14-20 owners to check as an alternate method to start infotainment diagnostics versus the headlight flash.
O6uzj100 (11-24-21)
LA Wheel
02-09-22 09:21 AM
ALIGN
ES - 6th Gen (2013-2018)
08-23-14 08:02 PM
jamodeo
01-30-14 11:49 AM
Rexus300
04-16-12 10:27 AM
350Dave
ES - 5th Gen (2007-2012)
08-26-07 06:57 AM
Quick Reply: '14+ Diagnostics
