The second screen is called "Service Menu". To access hold the INFO button on the center console and turn the headlight switch from OFF to ON 3 times. You will end up at the first pic. To fully exit the service menu you must turn the car off and back on then hit OK in the 2nd picture.
Not sure what is available for adjustment/settings. He just went into service menu for a quick check of product info and I discovered the 2nd by accident. Have not had a chance to play, maybe when the weather is warmer.
Access at your own risk
I got to the first screen , where is the info button? I can't find it .. Please show me ..
This is listed as starting in 2021 but something for 14-20 owners to check as an alternate method to start infotainment diagnostics versus the headlight flash.
