white residue under oil cap?
Old 03-19-14, 03:57 PM
tslz71
tslz71's Avatar
Default white residue under oil cap?
I just purchased a 2010 GX460 with 63000 miles. I saw a buildup of white residue under the oil cap the day of purchase but figured it was just moisture buildup from the car sitting on a car lot and not moving much. Well, after cleaning it off, it came back. I then thought maybe there is moisture in the oil so I took it to the local lexus dealer and had the oil changed. Well, its still coming back. The picture below is buildup from 2 days of driving, I cleaned it off monday afternoon and its wednesday afternoon. When checking the dipstick, I have almost completely clear oil as its new, then about 2 inches above the oil line to 6 inches above there is more of this white stuff. Should I be worried? Also, does the lexus drivetrain warrant that lasts to 70k miles apply to 2nd owners?
tslz71 is offline
Old 03-19-14, 04:14 PM
tecman
tecman's Avatar
checked my cap/dipstick and nothing but black at 50k miles. I think the drivetrain warranty transfers with any auto maker.
tecman is offline
Old 03-19-14, 04:37 PM
rockydog
rockydog's Avatar
From a quick google search:
One of the next signs of a blown head gasket is contaminated oil. You will notice a milky ring surrounding your oil cap. This is caused by coolant entering the engine oil through the leaking gasket. This mixture leaves the milky ring around the oil cap when it evaporates. You can check for this by taking the car for a short drive, then checking the oil for contamination.
rockydog is offline
Old 03-19-14, 05:31 PM
tecman
tecman's Avatar
That would explain the problem and if you have white smoke from the tail pipe along with excessive moisture that would confirm it.
tecman is offline
Old 03-19-14, 05:53 PM
tslz71
tslz71's Avatar
There is no smoke from the tailpipe. Im just confused at the moment and hoping it has something to do with a clogged vent line or something. A 2010 lexus thats been dealer maintained its entire life with extensive service records. A head gasket just wouldnt make sense unless its some ultra rare manufacturing defect.
tslz71 is offline
Old 03-22-14, 06:17 PM
tecman
tecman's Avatar
I looked into this again and found the following link and it does seem plausible with what you are thinking. I would be surprised if you have a blown head gasket without the other symptoms.Please follow up with your findings.
http://www.fjcruiserforums.com/forum...hat-world.html
tecman is offline
Old 03-22-14, 09:29 PM
T4Fun
T4Fun's Avatar
the warranty absolutely applies to 2nd owners. take it to lexus dealer and show them the white residue. i ve never seen this before.
T4Fun is offline
Old 03-23-14, 12:33 PM
Craig B
Craig B's Avatar
Me neither, I've never seen this on mine as well...
Craig B is offline
Old 03-23-14, 02:22 PM
T4Fun
T4Fun's Avatar
heres a good article on blown head gaskets
http://auto.howstuffworks.com/under-...ead-gasket.htm
is your antifreeze running low?
T4Fun is offline
Old 03-24-14, 10:28 AM
tslz71
tslz71's Avatar
I ordered a test kit from blackstone and will send off my oil for sampling. They will be able to tell me everything I need to know. Once I receive that information I will either see its a non issue, or have lab papers to take to my local lexus dealer and let them know what needs to be fixed.
tslz71 is offline
Old 03-24-14, 10:41 AM
Eppieguy
Eppieguy's Avatar
Great Idea, please keep us posted.
Eppieguy is offline
Old 01-23-19, 02:08 PM
Justin0728
Justin0728's Avatar
Did you figure it out would like to know I'm looking at a car and the cap looks just like this
Justin0728 is offline
Old 01-23-19, 04:26 PM
coolsaber
coolsaber's Avatar
Either moisture residue from quick frequent trips leading to moisture buildup or Headgasket.
If you own it, deal with it by either trying a powertrain warranty claim or see if the oil or coolant is displaying similar problems through a visual. Best bet is to sample the oil or use a radiator head gasket vapor tester if your DIYing the testing bit.
coolsaber is offline
Old 01-24-19, 06:13 PM
konc3pt
konc3pt's Avatar
Location: From Oakland to Sactown, the Bay Area & backdown
from my limited knowledge milky oil means blown head gasket
konc3pt is offline
jc12
GX - 1st Gen (2003-2009)
01-21-19 08:38 AM
mic575
02-13-18 12:34 PM
Sturds
RX - 1st Gen (1999-2003)
08-12-12 02:55 PM
sanjonmomo
07-23-11 02:13 PM
sagarx
11-03-09 10:23 AM
Quick Reply: white residue under oil cap?
